Battery Cables Upgrade
Old Feb 20, 2023 | 10:12 AM
tirefriar's Avatar
tirefriar
Originally Posted by z31freakify
Get the hard start option 3/0 starter cable it's the ****.
No doubt in my mind that 3/0 is the "****". I called Custom Battery, per them the 3/0 is for extreme weather conditions. They recommended going 2/0 for California. Ordered their set, should go out today.
I called ProSource Diesel and they confirmed that their set is not US made. In this case few bucks were used to buy me a piece of mind.
Thanks for all the suggestions. Next month's project should involve installing a TS 6 chip.
Old Feb 22, 2023 | 08:14 AM
Hit Man X's Avatar
Hit Man X
Are you using TS' stock tunes? Apparently they leave a lot to be desired. I have Gearhead tunes on my TS and they run well.
Good deal on your cables, it is a nice upgrade to have installed.
Old Feb 22, 2023 | 08:20 AM
tirefriar's Avatar
tirefriar
Where can I find info on Gearhead tunes? This is something I plan to do after the cables are in. Thanks
Old Feb 22, 2023 | 11:13 AM
knottyrope's Avatar
knottyrope
https://www.ghtuning.com/product-cat...3-powerstroke/
info on tunes
Old Feb 27, 2023 | 07:54 AM
tirefriar's Avatar
tirefriar
Originally Posted by knottyrope
Thanks a great deal for the link.
Wires arrived but the rains delayed the installation. Hopefully next weekend will be a dry one. BTW, the Custom Battery kit is excellent quality, very happy.
Old Feb 27, 2023 | 04:09 PM
JCart's Avatar
JCart
Highly recommend Hydra chipset with Jelibuilt tunes. Excellent customer service and Hydra tunes you can download from various sites and/or get updated custom tunes direct from Jelibuilt or favourite tuner. Hydra holds 15 tunes, should you want that many. In addition once installed, with optional cable you can add delete tunes without removing chip from PCM. So download generic or custom tunes from tuner. Take laptop inside truck plug into tuner cable and install/remove tunes. It is PC bases. Kinda makes most other chips/tuners obsolete IMO.
j
Old Feb 27, 2023 | 11:26 PM
tirefriar's Avatar
tirefriar
j
Very interesting, will definitely include that in my research. Thanks for the lead.
Old Mar 2, 2023 | 08:56 AM
Edgethis's Avatar
Edgethis
I run a Hydra with Jeli tunes. Makes my jalopy move down the road nicely.
I lucked out and made my own cables. Ended up with some cable for free. I just ended up buying the big crumpets and ends to make them work.
I did look at custom battery cables, they were super nice looking.
Old Apr 8, 2023 | 05:57 PM
zamboni's Avatar
zamboni
I just converted my OE cables to "military" type clamps.I have a hydraulic crimp tool so this only cost me the clamps, cable terminals, and a couple hours. OE cables are still serviceable and starting/electrical is otherwise strong, so this was better than a full cable job.
Couldn't figure out what terminals to buy, though, and this thread was one place I came looking for info before the project. Ended up just buying a little of everything and returning the ones I didn't end up needing. Based on what lugs fit on the freshly-cut-and-stripped cables, here's what fit my truck (per signature):
Passenger Side
  • 3/0 (+) Starter
  • 8awg (+) Starter Relay
  • 2awg (+) Crossover to DS
  • 2/0 (-) Block Ground
  • 10awg (-) Fender Ground
Driver Side
  • 2awg (+) Crossover to PS
  • 2/0 (-) Chassis Ground
Other Details
  • Military Terminals generally give you a 3/8" stud but watch out for the cheapies that only have 5/16". Some on Amazon are gonna come with metric hardware but they fit fine and terminals still slide over the not-actually-3/8" studs. If someone else works on your truck or you (gasp) have to take it to a shop, they will probably round off the hexes for you before realizing this.
  • I cut each cable off flush with the back of the clamp with a hacksaw, which was much less of a hassle than I expected and left pretty clean ends. I crimped the lugs onto what was left for all except the starter cable, which needed about an inch trimmed off. All cables landed comfortably on the new terminals once I figured out the best way to spin them.
  • I'll be on the lookout for a few "spare" feet of 1/0 or 2/0 to replace the crossover with. The OE cable has got to be really hard on the PS battery when starting.
Baja Fog
Oct 12, 2022 08:42 PM
Brockpend
Feb 24, 2022 08:55 AM
66v8baby
Aug 11, 2021 01:45 PM
mwoj
Jun 20, 2021 08:11 PM
82_F100_300Six
6.2L V8
29
Dec 1, 2020 02:44 PM
