Fuel Pump Issue
Old Feb 16, 2023 | 11:13 AM
HoraceFord's Avatar
HoraceFord
Fuel Pump Issue
’53 Ford F-100 239 Flathead V8
Rebuilt engine (purrs like a big cat), cleaned up transmission. Not bad for retired music educator.
Ran it about 3 miles and died. No fuel visible in the glass filter between fuel pump and carb. Glass bowl on fuel pump full of gas. AAA got me home.
Disconnected filter, turned engine over about 15-20 seconds and no fuel evident out of fuel pump. About ¼ tank of gas.
Removed fuel pump. Rotated engine, push rod moves freely up and down. Pushed rocker arm on fuel pump and gas squirted out of fuel pump fitting (toward carburetor). Air blown into intake side of pump pushed gas out same fitting. Able to suck fuel up on gas line from fuel tank.
New fuel pump installed 10/2017.
Looking for advice before I disassemble the fuel pump to see what the diaphragm looks like.
Thank you in advance.
Old Feb 16, 2023 | 12:59 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Is your filler cap vented?
The line from the tank to the firewall is the low point of the system, and all kinds of rust and dirt collects in there. Very hard to clean it all out. There is also a brass screen on the fitting at the bottom of the tank that could be plugged. Have you cleaned out the tank? If you remove the sending unit you can see down into the tank to see what's in there.
Old Feb 16, 2023 | 01:32 PM
HoraceFord's Avatar
HoraceFord
I did put in a new fuel sending unit as part of the 12 volt up grade. I'll take a look inside the tank and I'll check the filler cap.
Thanks.
Old Feb 16, 2023 | 03:57 PM
artscott61's Avatar
artscott61
Veteran: Navy
Ross have you ever used a company called Third Gen Auto for flathead parts ? Just bought a fuel pump from them quick service.
Old Feb 16, 2023 | 05:00 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Third Gen is very well-known in the Ford Barn world. I have bought from them, very good service and quick shipping.
Old Feb 16, 2023 | 07:15 PM
FortyNiner's Avatar
FortyNiner
Another Thirdgenauto.com fan. Michael Driscoll runs a good store.
RTT
17
Jan 12, 2023 07:44 PM
Number4
Jul 25, 2021 12:13 PM
dustof45
1947 and Older Ford Trucks
May 28, 2004 12:18 AM
olddawg
Jun 23, 2002 09:18 PM
