91 explorer--doesn't run good cold
Old Nov 15, 2003 | 08:01 AM
rustbucket64f100's Avatar
rustbucket64f100
I have a 91 explorer 4.0 it starts fine cold or hot, but doesn't have any power at all when its cold. Once it warms up it goes just fine. Any ideas?
Old Nov 15, 2003 | 02:29 PM
golfboy17's Avatar
golfboy17
how the rpm's when its cold???they should be at about 1500 to 2000 at idle when the engine is cold??
Old Nov 15, 2003 | 03:31 PM
Blly177's Avatar
Blly177
it is probrally running lean try cleaning the fuel injectors or maby the tps
Old Nov 28, 2003 | 10:18 AM
rustbucket64f100
what is the tps?
Old Nov 28, 2003 | 02:14 PM
marragtop's Avatar
marragtop
TPS is the throttle position sensor.
Old Dec 1, 2003 | 08:13 PM
rustbucket64f100
it runs like it isnt firing all of the time, it starts fine, just doen't run the best till its warmed up. just changed all the plugs, havn't changed the wires yet. also the sensor that is between the throttle body and manifold, does anyone know what kind of resistance it is supposed to have?
