351W roller engines
Old Feb 13, 2010 | 04:37 AM
OzPapaSmurf's Avatar
OzPapaSmurf
I there, I am a newbie here so please bare with me. A friend of mine has bought from the USA what he believes to be a Roller block but, the part number stamp on the block is missing the 4 and T. It has NOT been ground off but appears to have NEVER been there.
I work for a Ford Dealer here in Australia and no one from Ford Aus can tell me anything, I was wondering if anyone here can shed some light?
TIA
Old Feb 13, 2010 | 10:01 AM
Conanski's Avatar
Conanski
So what casting numbers are there?
The roller block is otherwise identifiable by a pair of raised bosses in the lifter valley that may or may not be drilled and tapped, and the top of the lifter bores will be machined flat.
Old Mar 8, 2011 | 12:53 PM
neekoli's Avatar
neekoli
Also wanting to find out if I have a roller cam or not.
I am looking at replacing my distributor in my 1995 F-150 XLT Supercab 4x4 with a 351-W and E4OD. The number on the side of my distributor is F4TE-12127-AA, would that indicate that I have a roller cam or not?? All the replacement distributors are either steel gear or iron gear, depending on if you have a roller cam or not. I'd rather not pull the distributor to find out. Thanks for your help.
Old Mar 8, 2011 | 03:54 PM
Beanscoot's Avatar
Beanscoot
Well if you have the original engine in your 1995 truck, it has a roller camshaft.
Old Mar 8, 2011 | 04:58 PM
neekoli's Avatar
neekoli
That's what I'm leaning towards, except for the fact that the auto parts stores, have two different distributors listed for my truck, one with a steel gear, and one with a cast gear.
Old Mar 8, 2011 | 06:29 PM
Shernius's Avatar
Shernius
The F4TE on the block I think is just going to tell you if it is a roller compatible block. I got one out of a 95 F250 4X4 and it had the roller cam in it but somebody already got the distributor. Can't complain too much since it was a low mileage engine out of a wrecked truck for only $150. Made it back selling the throttle body and intake.
Some 95s didn't have a roller cam in them but had the same block and I was thinking that maybe the engine code could be different.
Old Mar 8, 2011 | 09:11 PM
Conanski's Avatar
Conanski
The only '94+ truck engine that didn't get a roller cam was the Lightning.
Finding out what you have is pretty easy, remove the pasewenger side valve cover and shine a light down the front pushrod hole, once you get the angle just right you should see a dogbone around the lifter.
Old Mar 9, 2011 | 08:33 PM
neekoli's Avatar
neekoli
Thanks, I'll have to try that.
Old May 8, 2014 | 11:38 PM
cehenryj's Avatar
cehenryj
351 roller cam (96 Bronco)
my 96 Bronco xl came with 351 roller, standard
Old May 11, 2014 | 01:20 PM
baddad457's Avatar
baddad457
Originally Posted by jwtaylor
ONe way to tell the difference might be the gear on the distributor as roller require brass and non roller use steel gears. Another option, take the intake off and look for a spider retainer. Pretty easy.
You can use a brass gear on a roller cam but the steel gear is what should be used. Flat tappet cams used an iron gear, not steel. The quickest way to tell which cam in in the engine is to pull a valve cover, one rocker arm and pushrod, then measure the pushrod. The roller 351 rods are about 7.5" long. I've had two 95's now (pickup and a van) and now my 96 E150 van, all were roller cammed
Old Dec 24, 2016 | 01:55 PM
James Lowry's Avatar
James Lowry
I can
[QUOTE=jwtaylor;1095553]They also if I am not mistaken put out some old style 3/4tons+ in 1997 so if there is a 5.8 in a 97 then it probably has the roller cam as well. It's what I have been told
Howdy all,
I can verify this on the '97 F350 crew cab as I am currently in the middle of a engine replacement on one of these units that was run HOT by the (ab)user.
The spider plate and wishbone retainers are there in the lifter valley plain as day.
Old Dec 24, 2016 | 03:32 PM
Beanscoot's Avatar
Beanscoot
...and my F4TE 351 block from a 1994 F150 is also roller camshaft equipped. As Conanski has said, all 1994 and up 351 engines except for Lightnings came with roller camshafts.
I have read that some late production 1993 truck engines came with the F4TE cylinder blocks, but I don't know if they have roller camshafts fitted.
Old Feb 2, 2018 | 09:47 AM
  #28
needhelp49's Avatar
needhelp49
Originally Posted by Shernius
Can anybody tell me what years Ford made a 351W roller engine and what vehicles they were put in? Is it a 351 HO?
did ya notice nobody answered. It was a real easy question what years were roller.
Old Feb 2, 2018 | 11:51 AM
  #29
Shernius's Avatar
Shernius
Hey douche, did you notice that the original post was back in 2003?
  #30
baddad457's Avatar
baddad457
Did ya notice in your hurry to post a smart assed response that the question posed is EIGHT YEARS OLD !!!!
