Upfitter routing
Old Feb 12, 2023 | 02:25 PM
Squanto's Avatar
Squanto
Upfitter routing
I plan to wire up some of the switches soon. I expect 2 will be run to the bed and 1 may be under the bed. Would you run the wires from the relays under the hood and under the cab or would it be easier to go from the pass through wires in the pax kick panel?
Old Feb 12, 2023 | 02:37 PM
wheelerfreak's Avatar
wheelerfreak
If you're not running them to anything in the cab then there is no point in using the pass throughs in the cab. Run the wiring from engine fuse box area.
JDJR59
Feb 14, 2024 01:09 PM
Moe Craig
13
Jul 14, 2019 05:10 PM
Boatdude60
Sep 12, 2018 09:30 AM
davidmcintyre
6.7L Power Stroke Diesel
Sep 4, 2010 09:53 AM
Gwilkrrs
All Things Towing
May 25, 2003 05:54 PM
