Recon cab lights
Old Feb 12, 2023 | 10:17 AM
Sabrevt1100's Avatar
Sabrevt1100
4wd Low
Recon cab lights
Hello Team,
my 2020 F250 6.7 Liter did not come with cab lights, I have a local shop that does this type if install. Has anyone installed the Recons on a truck?
Old Feb 12, 2023 | 11:07 AM
Poncho450's Avatar
Poncho450
Originally Posted by Sabrevt1100
Hello Team,
I've seen threads on this here in the past. You can try the site's search function, but I never seem to have very good luck with it.
Old Feb 12, 2023 | 11:08 AM
Joe T's Avatar
Joe T
Yes its not a huge job. I assume they know the different mounting points between the panoroof and regular trucks.
Old Feb 12, 2023 | 02:43 PM
Living Proof's Avatar
Living Proof
I have purchased the kit but haven't installed it yet. It doesn't look too hard. The recon lights are smaller than I expected......
Old Feb 12, 2023 | 03:52 PM
Joe T's Avatar
Joe T
They look just like the factory ones to me.
Old Feb 13, 2023 | 09:16 AM
Log Hog Kust'em's Avatar
Log Hog Kust'em
My wife looked to add cablights to one of my old trucks for a Christmas gift. She could not find a shop that to install them. They said the aftermarket were prone to leaking. That was about 10 years ago,so thing may have changed
Old Feb 13, 2023 | 09:46 AM
JoeUser's Avatar
JoeUser
Just the thought of cutting holes in the roof gives me the heebie-jeebies, LOL.
I think I'll pass, and avoid any potential leaks. They'd be nice to have, but not worth the effort or leak risk, for me...
Old Feb 13, 2023 | 08:24 PM
Living Proof
I guess I haven't paid much attention, I was basing the size off my 2016.
Old Feb 14, 2023 | 06:40 AM
Pugga's Avatar
Pugga
No way I'd willingly drill 5 holes in my roof. The install isn't difficult, but the risks are high if you don't get the holes sealed up properly.
Old Feb 14, 2023 | 06:50 AM
pete6114's Avatar
pete6114
Exactly why i never order sun roofs.
Old Feb 14, 2023 | 08:05 AM
Mark250's Avatar
Mark250
I added Recon lights to my 2018. Lay out the locations and define the holes required with masking tape. You will need to cut a rectangular hole for the lights. I used a Dremel and cutoff wheel, easy to do. Worst part was taking the headliner down. I left it attached at the back. The wire runs down the right windshield pillar where a plug was already present. In addition to the foam seal, I added a bead of clear silicone as they went on. No issues.
Old Feb 14, 2023 | 01:55 PM
Joe T's Avatar
Joe T
just reseal it. Or do it right the first time.
Old Feb 15, 2023 | 07:16 AM
Pugga's Avatar
Pugga
Or, hear me out here... just leave the solid metal roof in tact and not worry about a sealant joint protecting your cab from water intrusion. Even with a proper install, no sealant is meant to be permanent, they're flexible and meant to be a serviceable item, they all have a life span, they all degrade over time. The sealant may outlive the useful life of the truck, or it may start to fail in 5 years. Unless it's a legality thing where you need clearance lights for how you're using the truck, I personally wouldn't risk it.
Sabrevt1100
Oct 8, 2022 10:08 AM
skidrow01
1997 - 2003 F150
Nov 12, 2008 05:49 PM
