Sponsored by: Real Truck
Speedometer works when it wants
Old Feb 10, 2023 | 12:00 PM
marbern11's Avatar
marbern11
3rd Gear
So I have an 05 f250 with a 6.0 4x4 I been having issues with my speedometer. Already changed three speed sensors two on the trans and one on the rear end. It works for a while then it just puts my truck into limp mode. Speedometer is going crazy then Stops working. Need help anyone know what I can do next?
Old Feb 10, 2023 | 03:40 PM
Djosbun's Avatar
Djosbun
Instrument cluster needs repair most likely. Circuit Board Medics is who you’ll want to use. It’s a common failure point IF you have diagnosed the issue correctly.
— Dave
Old Feb 10, 2023 | 04:04 PM
Nosferatu's Avatar
Nosferatu
5th Gear
Have you tried smacking the top of the dash? Worked on my Jeep.
Old Feb 10, 2023 | 06:44 PM
marbern11's Avatar
marbern11
3rd Gear
— Dave
would this cause the truck to throw the codes for speed sensor?
marbern11's Avatar
marbern11
3rd Gear
actually I have and nothing.
Old Feb 11, 2023 | 11:54 PM
p38fln's Avatar
p38fln
Mine just has the dash go completely dead other than the battery charge and SRS warning lights which function normally. The previous owner popped the trim ring off and showed me that if you grab the right hand wiring harness on top of the instrument cluster and pull down on it like you're trying to break it you can at least get it out of limp mode and can usually convince the speedometer to kick on for a few hours. Mine won't go into limp mode as long as I can get the dash to kick on for even a second after starting the engine.
xcroix
1983 - 2012 Ranger & B-Series
Jan 7, 2023 08:11 AM
ScorpionKing
54
Jan 12, 2021 11:37 PM
jamien2
19
Jul 21, 2017 02:19 PM
mikedepalma
Feb 18, 2016 10:54 AM
