Aerostar Ford Aerostar
Shake-Rattle & Roll
Old Nov 14, 2003 | 11:49 PM
afcro's Avatar
afcro
Shake-Rattle & Roll
Please Help! Everytime I go over even the smallest pot hole it feels that my front right wheel rattles. It's not loose, I pulled on it. ??? 93 XLT
Old Nov 15, 2003 | 04:48 AM
xlt4wd90's Avatar
xlt4wd90
It could be a couple of things:
1. A worn ball joint
2. A worn tie-rod end (is the steering unstable as well?)
3. Worn anti-sway bar bushings
4. Worn brake caliper pins
4. Worn anti-rattle clips on the brake pads
Old Jan 10, 2004 | 02:49 PM
wge's Avatar
wge
Had the same problem with mine, the clips that hold the calipers in place were worn and the calipers would bounce around. New I put the clips in upside down and everything is quiet. The proper thing to do is to get new clips, but when in the middle of now where!
Old Jan 12, 2004 | 01:39 PM
afcro's Avatar
afcro
Thanks for all your help. Now that the snow has melted here, I was able to find the problem. Right side tie-rod. Re&Re and now no more problem.
Thanks again!!!!
Andrew
