Sponsored by: Real Truck
Tub
Old Feb 9, 2023 | 03:35 AM
slownsy's Avatar
slownsy
Tub
I have a 2015 Crew Cap, what years are compatible bodywork.
thanks Frank
Old Feb 9, 2023 | 10:41 AM
Super Duty DJ's Avatar
Super Duty DJ
The body style remained the same with a few minor changes from 2011-2016. Depending on exactly which body part you are looking to replace, you may be more limited within that range.
Old Feb 9, 2023 | 04:53 PM
slownsy's Avatar
slownsy
Tub
It is the tub on the rear I am considering changing, so 11-16 the same ? , I know that in 17 they went to aluminium, will a later aluminium tray still mouth ok and body lines match?
Frank.
Old Feb 9, 2023 | 07:14 PM
Super Duty DJ
When you say the tub on the rear, I am assuming that you are referring to the bed which is used for hauling cargo? The body style changed pretty substantially in 2017 when they went to the aluminum bodies and the body lines won't match up well. There are a couple of threads where people put a newer aluminum bed onto an older Super Duty so you might be able to search for those and see how the body lines match up.
Old Feb 9, 2023 | 07:44 PM
Super Duty DJ
Here's a post that shows one of the aluminum beds matched up with an older cab. 2009 F350 bed swap
Old Feb 11, 2023 | 03:37 PM
slownsy's Avatar
slownsy
Tub
Ok thanks. Maybe best to stick with 2015 bed if possible, otherwise something in the 11 to 16 range.
thanks Frank.
Headviking
Sep 17, 2009 09:13 PM
Flozzie
Apr 30, 2003 09:36 AM
alpine
Nov 27, 2002 06:33 AM
bigninja66
Paint & Bodywork
Sep 6, 2002 12:25 PM
