Ford In-Vehicle Tech Discussion area for Ford Sync, Sync AppLink, MyFord Touch, Ford Supplied SiriusXM Radio, Ford Work Solutions, etc.
No audio from BlueTooth only
Old Feb 8, 2023 | 06:30 PM
Jwagner219's Avatar
Jwagner219
1st Gear
Angry No audio from BlueTooth only
I have a 2019 F250 super duty. Everything audio/radio works EXCEPT I cannot hear audio when using BlueTooth or hard connection. SIRI functions recognize my voice and follows commands, I just cannot hear transmitted audio. I have yet to find someone who has ever had this issue! Things I have already done:
Deleting devices
restarting phone/connections
unpaired/re-paird device
Replaced APIM
Tried all master restarts/reboots
New truck batteries
New usb cords
Replacing fuses
Ford dealership did a diagnostics (supposedly) and had nothing new to report. Told me I probably had a malfunctioning APIM, which I know is not true.
Even tried a brand new APIM and still had the same issue. HELP!!
Old Sep 5, 2025 | 06:23 PM
Joel Gutierrez's Avatar
Joel Gutierrez
1st Gear
Same problem
Hey, I have a 2017 f250 xlt, did the EXACT SAME steps to try and fix it and no luck. What did you end up doing? Ive been stuck with this for a while and cant figure it out. Just installed my new apim module and nothing.
Old Oct 7, 2025 | 09:17 AM
TP_68_XL's Avatar
TP_68_XL
5th Gear
I am experiencing the same issue. 2017 F250 Platinum. System does seem to be operating correctly but have no sound. No sound from radio or voice. It understands me but I hear nada. Was literally shopping for new APIM when I found this thread. I have no clue what to check next. If anyone ever finds a fix they will make the birthday card list.
Tried:
Deleting devices
Replace APIM- NOT Done= did not work for others- Save $$
Tried all master resets/reboots
New truck battery
New usb cords
Update to SYNC 3 From SYNC3.0 Build 19205 / Nav map NA 1 15 TO: SYNC 3.4 Build 23188 / NAV NA 2 24
********SOLUTION*******
UNIT IS FIXED: Issue was Factory Sony Amp. I picked up one from EBAY and Life is good again.
Old Feb 15, 2026 | 11:25 PM
chuckedmonson's Avatar
chuckedmonson
1st Gear
Any update?
Has anyone had luck finding a fix to this issue with the basic radio without the external Sony amp?
RoyMunson
Dec 21, 2021 03:50 PM
KedBruce
Jul 22, 2017 05:38 AM
ryanbodden2014
Dec 11, 2014 01:32 PM
jaxvt
Oct 27, 2007 09:07 PM
