OIL DRAIN PLUG
Old Feb 7, 2023 | 02:13 PM
Big-Red-Lariat's Avatar
Big-Red-Lariat
OIL DRAIN PLUG
We have a 2020 F150 Platinum and have always had it dealer serviced but now we have a COSTCO membership and it is more convenient for oil changes. I was surprised to hear COSTCO tell me they would only do an oil change if we bring them a new drain plug each time. They are apparently single use throw away plugs?
Is this really necessary and is there a good source of aftermarket supply for them or should we stick with OEM drain plugs? They have them on AMAZON. Any experience with these, good or bad and what is a good price to pay for the plug?
Old Feb 7, 2023 | 03:35 PM
rvpuller's Avatar
rvpuller
Veteran: Coast Guard
They aren't single use but can easily be damaged by a over aggressive tech. I change my own and have a spare but haven't had to use it.
Denny
Old Feb 7, 2023 | 07:54 PM
Beechkid's Avatar
Beechkid
IMHO, worst thing you can do is take any vehicle to Costco, Jiffylube, etc. for an oil change.
Old Feb 7, 2023 | 10:57 PM
lv2race's Avatar
lv2race
What Beechkid said ^^^^^^^, and I agree with a tech jacking up your threads, even the Ford tech. Been there done that.
Buy 9 quarts, a filter, do it yourself, and torque correctly.
Old Feb 8, 2023 | 05:24 AM
2dwoods's Avatar
2dwoods
I've done many with my 18 and the plug in mine is fine I even kinda like it but I can see were a idiot could brake it
Old Feb 8, 2023 | 09:42 AM
Olds64's Avatar
Olds64
Definitely do the oil changes yourself. I have 2 or 3 free ones left from the dealer. After that I'm doing it myself.
Momma has a 2019 Fiesta. The dealer we bought it from screwed up oil changes twice by not torquing the oil pan drain bolt or leaving the fill cap off. She doesn't want me to do it so whatever... happy wife happy life.
Old Feb 8, 2023 | 01:25 PM
scott91370's Avatar
scott91370
Wouldn't say they're any worse than a dealer. Took our brand new vehciel in for its first oil change. Wife calls and says its making a noise. Luckily she was still in the driveway of the dealership. They told her it was only 1 quart low but I know better. Low oil light and noise do not start with only 1 quart missing.
Thankfully we're at 200k on it now and it hasn't had any problems and doesn't use oil.
Old Feb 8, 2023 | 01:47 PM
lv2race's Avatar
lv2race
My daughter took her Scion to a Toyota dealership for a $20 oil change. The "mechanic" must have spun the drain bolt on with an air ratchet because he stripped it. Didn't tell her, and she called me later about a pool of oil on the floor. Talked to the service manager, he tried to tell me the bolt should have been replaced because they wear out. I said I work in a machine shop and know way more than he does about metals and metallurgy, and the metal bolt can be removed and reinstalled several times with no issues. He had to replace the pan at his cost, glad he had one in stock.
Also took my '90 F150 to Goodyear in HB years ago for the "oil change special". It was a real special! They drained the oil, but didn't put any back into the engine. Got a block away and it got very loud under the hood. Checked the oil, stick was dry, idled through a parking lot back to Goodyear and said thanks for the "special". Made him sign the receipt stating I drove for a half mile without oil they forgot to put in.
Long story short, I will always do my own oil changes!
Old Feb 9, 2023 | 05:48 AM
Fat Ford Boy's Avatar
Fat Ford Boy
I carry a extra plastic oil pan plug in our 2017 K/R with a 3.5. I did that because I didn't know if there would ever be a "shortage" of them.
Old Feb 9, 2023 | 12:50 PM
GlueGuy's Avatar
GlueGuy
Stuff like that must happen all the time. Back in my youth, I had a Honda 350 "Street Scrambler"; kind of a hybrid on-road/off road" bike. I had some work done on it at the local Honda dealer, and as part of the service they threw in an oil change.
A bud dropped me off to pick it up, and I hopped on to high-tail it over to the place where I had a summer job. Got about 1/2 way there and the engine seized, hard. The back wheel locked up and I skidded to a stop. Come to find out they had failed to put any oil in it. I guess it was my fault for not checking, but in my defense, I was young. They ended up buying the bike from me, so good on them for owning the error.
Old Feb 9, 2023 | 01:05 PM
david kallin's Avatar
david kallin
4wd Low
It's not the plug so much as its the washer on the plug. These used to be single use copper plugs way back when but have become made of of many materials such as plastic, etc. Also there is a torque spec. that is supposed to be used. Very few do that combined with shade tree mechanics that torque to whatever they think is right,
That is why they drip, leak? Single use copper was replace by the other washer plugs with Speedy oil change stations who use young inexperience personal who
don't know spit about a vehicle and there you it ! That's why I change my own oil, add my own oil, air my own tires, etc. If something happens its my own fault? Bottom line is you can but those copper washers on-line at Amazon, or you can have an extra oil drain plug that you carry in your glove box?
Old Feb 9, 2023 | 01:57 PM
diesel_dan's Avatar
diesel_dan
I'm not sure what the folks in your thread are talking about with the stripped threads and copper washer comments. Your 2020 plug should be a plastic one with an o-ring for sealing - it takes only a partial turn counter clockwise to remove the plug and let the oil out, reverse to put it back. They are not single use plugs and there is no "torquing" to be done...
Old Feb 9, 2023 | 08:15 PM
lv2race's Avatar
lv2race
If it's the 2.7 or 5.0 with a plastic pan, you have the plastic drain plug. They're telling you to have one because the plastic tabs are known to snap and the o-ring may not seal correctly. They don't want to be responsible for an oil leak. I stand corrected, get a new plug.
Or change your own oil
Old Feb 10, 2023 | 01:38 PM
COFLHTK's Avatar
COFLHTK
Currently the dealer does my truck, but every other vehicle we do at home. Buy a fumoto valve and do it yourself.
Old Feb 10, 2023 | 02:09 PM
lv2race's Avatar
lv2race
Fumoto doesn't have the plastic drain plug option.
