Need to sort out...
Old Feb 23, 2023 | 10:20 AM
knottyrope's Avatar
knottyrope
if you dont have a small outlet on the radiator, just run hose to passenger head and water pump.
mine does not have a T in it.
also good to add in a 1/2 ball valve with hose barbs to limit flow during summer for more cooling.
Old Feb 23, 2023 | 10:32 AM
56Mater's Avatar
56Mater
Thanks for the tip knottyrope. I will look into the valve.
Old Feb 23, 2023 | 11:43 AM
helifixer's Avatar
helifixer
or do the ford ranger valve which lets the water continue to circulate
Old Mar 6, 2023 | 07:17 PM
56Mater's Avatar
56Mater
Ok, everything is hooked up from what I can see but apparently not since it will not start. Got batteries and they are full charged. I checked the power distribution box and all the fuses were missing. So I installed new ones, even ones that have a light but they are not lighting up. I don't think the box is getting power? Dash will not light up or even display miles. No start, no noises. Had to install a new key cylinder. Thoughts on where to check next?
Old Mar 6, 2023 | 08:11 PM
z31freakify's Avatar
z31freakify
Did you install all fuses or just the ones in the pic?
Just for reference here's the fuse locations and you need a diode as well.
Old Mar 6, 2023 | 08:12 PM
z31freakify
Also did you check the ones under the dash board on driver side?
Old Mar 6, 2023 | 08:30 PM
56Mater's Avatar
56Mater
Based on that picture, they are different. Is that a fuse panel for the diesel f250 96? I couldn't find a good resource for it. Does someone have a good diagram? Some of the missing ones are for the trailer stuff which I skipped for now. I will double check the dash one again but none were missing. Which one would affect starting and dash not functioning?
Old Mar 6, 2023 | 08:38 PM
z31freakify
Old Mar 6, 2023 | 09:06 PM
56Mater's Avatar
56Mater
I found a website that possibly more correct but still nothing. Corrected what was under the dash but need someone to double-check. Thanks
Old Mar 7, 2023 | 07:35 PM
56Mater's Avatar
56Mater
Anyone know the part number of the diode ? I can't find it at the auto parts store and searching on the internet get many different kinds.
Old Mar 11, 2023 | 12:28 PM
56Mater's Avatar
56Mater
Got the diode from junkyard but still no power to the power distribution box. I see the battery wire go to the starter but does a battery wire connect to something else? I am missing something. I can't find a diagram that shows exactly what connects where for power. Any help would be appreciated, I know I am close.
Old Mar 11, 2023 | 01:31 PM
56Mater's Avatar
56Mater
Where would the 300a fuse be? I can't find it. That would cause my problem too but can't find it.
Old Mar 21, 2023 | 10:04 PM
  #28
56Mater's Avatar
56Mater
ok, figured I update the thread and jump to another for the hopefully last issue before starting it.
So I had installed the fuses, all the remaining parts that were missing but the truck wouldn't start. I found out what the final part I was missing. The cable that goes from the battery to the starter solenoid. I figured that out when I bought new positive battery cables and they had something I was missing, that extra cable. I hooked it up the starter solenoid but I installed it on the wrong post and when I connected the battery, i guess it was bypassing the starter solenoid and the truck tried to start. I put the cable to the correct post and now the dash powers up and tries to start but I have another issue now.
I had to buy a new key cylinder, with keys. The one for the security system that ford has. The truck will not start because the theft light is on. Trying to find a solution to reset this to accept the new key. I do not have the key fob, lost.
Old Mar 22, 2023 | 07:53 AM
  #29
manicmechanic007's Avatar
manicmechanic007
With all you have done, you should be able to get the key programming figured out
You could do it yourself maybe using FORScan, if you were to jump through the hoops
Might be more cost effective just to get a locksmith over to the truck
I would get a couple of Ford fobs and program them at the same time
You should be able to do that yourself (easier) just by turning the key on and off after you get that part fixed
Old Mar 22, 2023 | 08:14 AM
  #30
knottyrope's Avatar
knottyrope
Key
  1. Insert the key into the driver's side door lock.
  2. Turn the key once, but not all the way to unlock the door. Leave the key in this position for 40-60 seconds. ...
  3. Do this again, but turn the key in the opposite direction.
  4. Remove the key from the door, get into your Ford, and start the engine. The system should be reset.
https://moduleexperts.com/ford-pats-relearn-procedure/
