Hello, I have a 71 f750 dump truck I am redoing the rear brakes on. Have all new brake parts for it but am having a very hard time finding new drums. Drum and hubs are one piece, 10 lug, split gear Eaton axle. and nobody I speak to seems to be able to turn the drums I have as they are too large, also they are so rusted half the people I've spoken to say they are shot and need replacing I have spoken to every single shop locally. I cannot find anything close to what I need everywhere I look so I am coming here hoping somebody may have some advice, thank you
-John, grants pass Oregon
Thank you, apparently nobody in town has a lathe big enough to do this. Not too many wrecking yards either, Im skeptical I would find something this old easily but will start looking. Left drums in town at one shop that might have a lead... Will have to measure them and get back on here.
Hub and drum are two piece
10 lug sounds like you possibly have air brakes as most of the trucks that size in the 60/70’s with hydraulic brakes had 6 lug rims
But anything is possible
I had to do a ton of research putting new brakes on my f700, I can probably help you out but I need some information. First off, air or hydraulic brakes? Second, brake width and drum inner diameter? I'm assuming you are using Budd rims?
