spark plug gap - one more time
Old 11-14-2003, 08:44 PM
bob-63-292's Avatar
bob-63-292
bob-63-292 is offline
My manual calls for a 0.30" plug gap (63 292). However, I seem to recall that for best power, you want the biggest gap your coil can handle (bigger spark, faster burn, etc.).
So, my feeble memory would hint that a better coil means I can run a larger gap.
Is this so, or am I just imagining???
Bob
Old 11-14-2003, 11:14 PM
canzus's Avatar
canzus
canzus is offline
Yes, however, if you get a misfire at higher
rpm, you gotta close it up a bit, until the misfire
goes away, it's the same with the timing, advance
it 'til it pings, then back off a few degrees...
RIKIL
12-15-2014 02:34 AM
1959_f100
12-23-2008 10:25 PM
getsch58
06-22-2006 09:00 AM
aries
06-12-2003 12:01 PM
Quick Reply: spark plug gap - one more time
