Exhaust Overloaded Message
Old Feb 1, 2023 | 12:37 PM
texczech's Avatar
texczech
Getting the exhaust overloaded drive to clean message. I assume there is a pressure sensor in the exhaust that senses high pressure and causes the message to clear. I see on the scanner some data.Looks like there is an exhaust pressure sensor that reads in psi and an exhaust pressure sensor voltage reading. What numbers would cause the message to come on? I am assuming that these are readings used to determine when to clean. Thanks!
Old Feb 1, 2023 | 01:13 PM
Overkill2's Avatar
Overkill2
Okay so I Iooked into this for you.
From here, Jun 4, 2018
2015 F-350, 6.7, 24000 miles. I received the Exhaust Filter Overload for the first time. I ran the Vehicle Diagnostics Report and within 5 minutes I received a report from Ford via email noting the fault code and remedy. Run your truck at least 30MPH for 20 continuous miles. I happened, to be at an entrance on I-40 (75MPH speed limit) and followed the instructions to clear the fault. It took my truck 23 miles to clear the fault, haven't seen it since. Prior to doing this I called the local dealer because the fault stated to "contact dealer" in RED vice the normal yellow warnings. Was told to bring it in because it was a serious problem and needed their techs to run a diagnostic check for a fee. I had been towing a 13000 LB 5th Wheel for almost 1000 miles over a 10 day period in a very mountainous region, not towing when clearing the fault.
One from here... in this forum...
It sounds like it MAY be a programming issue... not sure. I have a 16 and daily drive my truck. I have never had a problem with the DPF and have never seen this message...
Old Feb 2, 2023 | 05:14 AM
senix's Avatar
senix
I would get it on the road for that long drive a hwy speed and see if it will clear/clean itself out.
Will Bite
Oct 2, 2021 07:53 PM
ruschracing4
May 17, 2015 01:01 PM
Faster71
Feb 23, 2014 05:57 PM
bloomy63
Dec 7, 2006 08:07 PM
