Rumble in park
Old Jan 29, 2023 | 10:50 PM
Powerstrokef250's Avatar
Powerstrokef250
4wd Low
Rumble in park
I have a 2000 f250 with the 7.3 with a 4r100. When the truck is in park it runs fine but if I hit the accelerator and let off the truck drops down to normal rpm’s then a few seconds later there’s a rumble right under my feet, and that’s the only time I notice it. It does not seem to be affecting anything but if anyone has any idea of what it could be it would be much appreciated. If I can I will get video of it tomorrow.
Old Jan 29, 2023 | 11:42 PM
udsuth78's Avatar
udsuth78
Sounds like you may have a busted flexplate. It's somewhat common for these trucks. The plate cracks between the bolt holes mounting it to the crank. The washers hold it in place for the most part but it can vibrate at different rpm's and loads.
Old Jan 30, 2023 | 07:13 AM
Kwikkordead's Avatar
Kwikkordead
My first thought is a broken flex plate as well. The sound shows up at idle more than at speed because of all the inertia of the spinning parts tends to quiet down the interaction between the broken pieces.
Old Jan 30, 2023 | 08:11 AM
'88 E-350's Avatar
'88 E-350
My first thought was torque converter. I forgot exactly which part wears out and rattles, but I think it's related to the clutch. I can't feel mine and I don't know if it can get bad enough to feel so that may not be your problem. I can hear it, but it only became obvious after driving it with the cover off, now I can tell even with the cover on. The sound goes away in gear or if I manually engage the clutch while in neutral.
Old Jan 31, 2023 | 04:17 AM
FordTruckNoob's Avatar
FordTruckNoob
I misread the title as rumble in the park and was getting ready to be all West Side Story. My bad. Carry on.
Old Jan 31, 2023 | 06:24 AM
udsuth78's Avatar
udsuth78
Have you been re-watching Glee again? Remember the whole world is not a musical.
Old Jan 31, 2023 | 01:08 PM
knottyrope's Avatar
knottyrope
Please post video with sound including tach on dash
mrk28645
Jun 17, 2017 09:47 PM
okrp
Oct 2, 2016 09:49 PM
1996_powerstroke
15
Jun 5, 2016 07:50 PM
andres0517
Nov 3, 2013 07:59 PM
andres0517
Nov 3, 2013 01:59 PM
