What is this???
Old Jan 28, 2023 | 08:38 PM
Jeff Wecker's Avatar
Jeff Wecker
What is this???
I was looking things over under my 1986 F150, when I stumbled across this housing with 4 lines going in and one going out. Looks like it's a secondary fuel filter, that takes some sort of cartridge filter. Am I correct? Attaching photo of the part in question. I'm assuming the bottom unscrews to replace the filter in it?
Old Jan 28, 2023 | 10:43 PM
FuzzFace2's Avatar
FuzzFace2
Truck have EFI and dual tanks?
You did not say what motor you have but are you sure you dont have 6 lines total to it?
2 from the motor side: supply and a return to the motor.
The other 4: 2 should be supplies 1 from each tank and the other 2, 1 each returns to the tanks.
You are right about the filter and the bottom should unscrew to replace it.
It is also a srurge tank with the EFI system.
Dave ----
Old Jan 28, 2023 | 11:34 PM
Jeff Wecker
Dave ----
I have the 5.0. Yes I think it has 6 lines total. Has the normal canister inline filter on the outlet side of the frame mounted high pressure pump.
Dual tanks with EFI
Old Jan 29, 2023 | 03:19 AM
Ken Blythen's Avatar
Ken Blythen
Some models had no filter in that bowl.
I had an '88 F150 (injected 351W) for a while, that I assumed would have a filter there in need of changing...but discovered there wasn't & wasn't meant to be.
Old Jan 29, 2023 | 01:41 PM
Lariat 86's Avatar
Lariat 86
I have a 86 F150 XLT Lariat with the MFI 5.0 and duel tanks too. That is the switch for which tank you are using and it should have 4 lines on the back side and 2 on the engine side. Mine does have a filter in it. Here’s a link to what it looks like:
https://www.stockwiseauto.com/motorc...rd&Model=F-150
Old Feb 14, 2023 | 08:40 AM
Jeff Wecker
Got that filter off this past weekend, here is what it looked like with crap from the old front tank:
A replacement front tank and in tank pump/sending unit installed, and lines blown out ( they had no dirt in them) Also replaced high pressure pump and filter, lines were clean, and the gas emptied from those was clear.
Old Feb 14, 2023 | 11:22 AM
kr98664's Avatar
kr98664
Wow, you know that filter must have been in there a long time. It still says "Made in USA"...
Old Feb 14, 2023 | 05:46 PM
Olds64's Avatar
Olds64
Were you able to find a replacement filter element?
Old Feb 14, 2023 | 07:07 PM
Franklin2's Avatar
Franklin2
Did you know when Ford manufactured that assembly they considered it a "lifetime" filter? That is probably true if you buy a new truck every 10 years.
Old Feb 14, 2023 | 10:09 PM
BigBlue2's Avatar
BigBlue2
Hmmm, looks pretty robust. Done it's job well. Maybe clean it carefully and replace it if not too plugged up?
Old Feb 15, 2023 | 07:51 AM
FuzzFace2's Avatar
FuzzFace2
NAPA Gold is top of the line filter
Dave ----
Old Feb 15, 2023 | 07:24 PM
Jeff Wecker
Yes, MicroGard part number 33268 @ O'Reilly
Old Mar 4, 2023 | 08:13 PM
Jeff Wecker
While attempting to start my 1986 F150, I notice gas dripping underneath. I looked and it was dripping from that fuel reservoir thing. The O ring that was in the filter box was not the same diameter as the old one, which I had to reuse. Am guessing the old one had a crack or something, that's making it leak past it. What's the diameter of the o ring that seals it, so I can source one from my local parts house, or is there something else I can use to seal it
Old Mar 5, 2023 | 07:40 AM
Franklin2's Avatar
Franklin2
I would try the one that came in the filter box. Also make sure you get it very tight on there. It was very difficult to get unscrewed correct? Put a little oil or grease on the new o-ring, so when the cap spins on it will not roll up the new o-ring.
Old Mar 5, 2023 | 12:14 PM
Rusty_S's Avatar
Rusty_S
Same as my dads '89 E150 van with 5.0 EFI engine. I checked it thinking that was why the engine wouldnt run anymore and there was minimal fuel pressure. Took the bottom reservior off and there was no filter. I looked online and there was no listing for a fuel filter for this application. Ended up being the lift pump in the tank that took a crap and I had to drop the fuel tank and replace the fuel pump.
