What is this???
Old Mar 12, 2023 | 09:29 AM
  #31
BigBlue2's Avatar
BigBlue2
You can use wheel bearing grease to hole the ring in place and lube it at the same time.
I would not use Permatex unless I really really really needed to.
Dave ----
Yes, use grease. I was thinking the groove was up and that's why you were having an issue. Let gravity do the holding in.
Old Mar 12, 2023 | 09:44 AM
  #32
FuzzFace2's Avatar
FuzzFace2
Even if it is up, grease will hold it in place long enough to get the cup in place.
The Permatex may "seal" the cup to the housing and at a later date not be able to undo it.
Dave ----
Old Mar 12, 2023 | 09:48 AM
  #33
BigBlue2's Avatar
BigBlue2
Dave ----
#2 remains pliable and is compatible with gasoline. But yes use grease.
Old Mar 12, 2023 | 08:15 PM
  #34
351Cleveland C4's Avatar
351Cleveland C4
The small Oring goes on top of the filter.
For the cap, these are what you need.
Old Mar 17, 2023 | 01:27 PM
  #35
BigBlue2's Avatar
BigBlue2
Dave ----
If you put an amount of permatex in the groove that it seals the cup, then that would not be an example of using a very very tiny amount. That said I wish I would not have suggested it. Grease would be better for most people to use. And a tiny amount of grease or oil at that.
six_eaux
Nov 11, 2021 07:16 AM
jovol
Large Truck
Apr 13, 2021 09:54 PM
wwanderson555
19
Mar 30, 2015 11:58 PM
GSlahor
Aug 15, 2013 06:04 AM
HKusp
17
Feb 3, 2008 06:39 AM
