Aftermarket Products
Sponsored by: Worksport
Fog light recommendation...
Old Nov 14, 2003 | 04:42 PM
Kingsun's Avatar
Kingsun
The next thing I want to install is a good functional fog lights. I love to go to the coast to fish and every once in awhile it gets real foggy..I've seen the triangular looking driving lights on the lower bumper of some F150s and I'm quite interested in those.Where do I get them and do I have to drill holes?? Any recommended options.. I know a real good looking one is a bush guard w/ foglights but they are too pricey.. Thanks for your thoughts...
Old Nov 14, 2003 | 07:30 PM
StrangeRanger's Avatar
StrangeRanger
Fogs and drivers are two different things. Fog lights give very little increased illumination in clear weather. They have the same bulbs and usually the same reflectors but VERY different lenses. Fogs throw a very wide diffuse beam with a very abrupt cutoff at the top edge. The "fog lights" on most, if not all, US production vehicles are not true fogs, they are more nearly cornering lights, basically low powered drivers.
BTW you want fogs mounted as low as possible for the full effect in the fog. Take the control power for the relay off the parking lamps, not the low beams. That way you can run on fogs only when it turns to pea soup. (Not legal, but who's going to catch you when it's that thick?)
Old Nov 14, 2003 | 09:41 PM
Kingsun's Avatar
Kingsun
Thanks for the quick response.. Yes, sir I want a quality fog lamp not the driving lights and I realize that w/o fog it's next to useless but I've driven thru fogs w/ almost zero visivility and I am wondering if a good foglight will help me see better.Thanks again.
Old Nov 15, 2003 | 07:34 AM
StrangeRanger
I've got Hella 550s. They work very nicely. Cibié makes very good lights too, but they're a bit harder to find
Old Nov 15, 2003 | 08:15 AM
Kingsun's Avatar
Kingsun
Where and how did you install them..Thanks!!
Old Nov 15, 2003 | 10:46 AM
StrangeRanger
I used a Smittybuilt Outland brush bar. It will hold 6 lights. I mounted (2) drivers above the light bar anf hung (2) fogs underneath. For the newer trucks like yours, they make the "Outland Sport" which is a whole lot smaller, basically just a light bar.
Old Nov 15, 2003 | 11:46 AM
Kingsun's Avatar
Kingsun
Thanks again for the info...Looks like I've got to go the "bush guard way" so I get more options as to the type I want to use...
Old Nov 16, 2003 | 04:12 AM
PW01's Avatar
PW01
I like the Hella 500's
Old Nov 20, 2003 | 03:16 PM
horizonhuskies's Avatar
horizonhuskies
I added on a valence with fog lights cut out. Install was simple. We wired it so that the fog lights come on with the parking lights. I like the way they work, and since its just a mounting stud and bolt, you can adjust where they shine. The time of year there is no fog they are angled higher to hit right about where my low beams are. 2 weeks ago I pointed them lower in order to get the actual fog light functionality from them. Just my $.02
garrett
Old Nov 20, 2003 | 04:37 PM
Kingsun's Avatar
Kingsun
Thanks to all for your responses....
