AC compressor doesn’t turn on
Old 01-24-2023, 01:00 PM
Anonymous12's Avatar
Anonymous12
Anonymous12 is offline
I have a 88 f150, and it has an AC compressor that won’t turn on. I know this usually means it’s low on R-12 from a leak, but with the regulations on that stuff I’m hoping it’s not that. Is there any other thing that can cause this I can look into? If not it’s gonna have to go to a shop to get a 134a conversion put on it. But will shops even handle the R-12 to take that system out?
Old 01-24-2023, 03:49 PM
jas88's Avatar
jas88
jas88 is offline
Check to see if you have 12V+ on one side of the low-pressure switch which is on the accumulator on the passenger side under the hood. If you do have 12V+ on one side, jump it and see if the compressor engages. If so, either bad switch or low on freon.
Old 01-24-2023, 03:59 PM
Anonymous12
Will this still work without the engine running? Or will there be some noise when the compressor engages? I can’t start it right now.
when I press the AC switch in the climate control it doesn’t light up either. Could be a bad bulb. Don’t know if that gives anymore info.
Old 01-24-2023, 05:32 PM
jas88's Avatar
jas88
jas88 is offline
Turn the key and the a/c on. If the compressor engages, you will hear a click.
Old 01-24-2023, 05:38 PM
mlanoux's Avatar
mlanoux
mlanoux is offline
You could also start the truck up, turn the a/c switch on, then disconnect the low pressure switch and jump it with a paper clip...if compressor turns on, you're either low on freon or the switch is bad (probably the former).
Old 01-24-2023, 06:06 PM
My4Fordtrucks's Avatar
My4Fordtrucks
My4Fordtrucks is online now
Received 1,420 Likes on 1,120 Posts
Umm…. How to jump the low pressure switch covered in post 2 and the OP stated he has a non-running engine in post 3.
Old 01-24-2023, 07:18 PM
mlanoux's Avatar
mlanoux
mlanoux is offline
ugh, it's been a long day...must have scrolled right past that and missed it...my bad
Old 01-24-2023, 08:15 PM
Anonymous12
I’ll try it this weekend when I fix my water outlet leak. But I still won’t start it because I’ve got a new PS pump in and I still need to flush the system.
Old 01-25-2023, 06:45 AM
My4Fordtrucks
You can and should flush the system without starting the engine. We now return to our regularly scheduled program.
Old 01-25-2023, 09:11 PM
kenny nunez's Avatar
kenny nunez
kenny nunez is offline
Ac clutch
If all other checks and are in good condition make sure that there is no more than .025 clearance between the clutch halves. Too much clearance will not allow the clutch to engage.
Old 01-25-2023, 09:59 PM
DBGrif91's Avatar
DBGrif91
DBGrif91 is offline
I just wanted to add that the clutch coil would still pull on the clutch disc and it would be attempting to engage the pulley.
Depending on the factors, compressor lockup may occur, noises and/or a brake-burning-type smell could also be present.
In the few encounters I’ve had with excessive AC clutch air gap, it tends to result in a pinging or squealing/whistling type sound; it’s also usually a symptom of other AC system issues that cause the compressor to work harder.
Old 01-26-2023, 07:48 AM
kenny nunez
AC clutch
Agree, Last summer the clutch on my Sport Trac would disengage due to excessive clearance. However it did not make any noise. There was enough shims that I removed to tighten it up.
Old 01-28-2023, 04:26 PM
Anonymous12
So I tested it. With the blower motor on low and the ac switch turned on the climate control panel it has power 10-11v. And when I jumped it the clutch engaged.
Old 01-28-2023, 06:14 PM
kenny nunez
AC clutch
Just for kicks check the clearance of the clutch halves air gap.
Old 01-28-2023, 09:46 PM
Anonymous12
How would I properly do that? And how would I tell if it’s the switch or the Freon? And why didn’t I have battery voltage there? Is it referring to the switch on the climate controls or something else?
Quick Reply: AC compressor doesn’t turn on
