Running lights stop working intermittently
Old Jan 24, 2023 | 08:37 AM
NRD's Avatar
NRD
My 2019 Lariat F250 running lights (taillights, mirror lights, license plate lights) will stop working. Brakes, and turn signal work. If I cycle the lights from auto to on they start working again. It’s happened twice last night with a trailer hooked up. Trailer lights were all functioning. I’ve read other posts where the running lights completely stop working but I didn’t see any where they come back on after cycling lights. Any idea what could be causing this? TIA
Old Jan 24, 2023 | 08:59 AM
2008f250xlt's Avatar
2008f250xlt
Check this connector
Passengers side. Use dielectric grease. Know to get water in.
Old Jan 24, 2023 | 11:20 AM
NRD's Avatar
NRD
I pulled that plug it was bone dry with no signs of corrosion, cleaned and greased it. 🤷‍♂️
Old Jan 24, 2023 | 01:33 PM
jimzpsd's Avatar
jimzpsd
Being all the running lights, I would try a new headlamp switch.
https://www.tascaparts.com/oem-parts...xoCUr0QAvD_BwE
Old Jan 24, 2023 | 07:51 PM
KU4OJ's Avatar
KU4OJ
In "auto" mode, with halogen headlights, the running lights will shut off in bright daylight leaving the headlights on as DRLs. Maybe there is something wrong with or interfering with the light sensor?
Old Jan 24, 2023 | 10:55 PM
NRD's Avatar
NRD
Lights worked fine all day with it set to auto, it was dark and storming so the lights stayed on🤷‍♂️
Old Oct 13, 2024 | 10:58 PM
ktnissen's Avatar
ktnissen
Did you ever figure out what caused this issue. My 2019 F450 Flatbed is now having this problem. They turn on, stay on for a few minutes then I have to cycle auto to on and they come back on. Does not affect my headlights or trailer running lights.
Old Oct 26, 2024 | 07:22 PM
NRD's Avatar
NRD
Sorry for the late reply. I cleaned and greased the two plugs under the truck attached to the trailer hitch and did the same with the taillight plugs.
Earn88fan
Sep 7, 2021 07:59 AM
UYates
6.7L Power Stroke Diesel
Oct 29, 2018 07:49 PM
cgeer33
Jul 29, 2017 06:49 AM
Titanrulez
General Automotive Discussion
May 6, 2015 07:33 AM
GR8 1
Sep 10, 2003 12:49 AM
