back up lights on when lights on
Old Sep 8, 2003 | 07:58 PM
GR8 1's Avatar
GR8 1
My 86 ford f250 b/u lights are always on when my head lights are on I can't get my inspection sticker until I fix it. PLEASE HELP
Old Sep 8, 2003 | 09:26 PM
1987LTDmasta's Avatar
1987LTDmasta
hrm... how about when you hit the brakes? its very likely just a short in thewiring by the tailights.. if you have aux wiring for a trailer, check the wiring there.
you may have also installed the bulbs in the wrong sockets on the tailamp assembly..
Old Sep 9, 2003 | 01:22 AM
Mil1ion's Avatar
Mil1ion
Do you have running lights at the same time ?
Old Sep 9, 2003 | 08:05 PM
GR8 1's Avatar
GR8 1
Yeah I have running lights at the same time
Old Sep 10, 2003 | 12:33 AM
packlet's Avatar
packlet
have you checked your neutral safety switch?
you might have such symptoms if it shorted.
mine died open. it's not an easy part to find. to get the backup lights working again, i bypassed the NSS and put a manual switch on the dash...
Old Sep 10, 2003 | 12:49 AM
Mil1ion's Avatar
Mil1ion
Pull the fuse for the B/U lights.
If they are getting power from the running lights the B/U lights will stay on when the fuse is pulled.
If they go out, the problem is part of that circuit.
