rocker arm question
Old Jan 23, 2023 | 02:29 PM
catastrophejustin's Avatar
catastrophejustin
rocker arm question
thank you in advance if anyone can point me in the right direction. i have a 390 fe basically stock with a 4 bbl intake i am building. i was given a edelbrock performer rpm cam and lifter set but i am not sure if the stock rockers will work. if not does anyone have any recommendations that wont break the bank? i would appreciate it.
Old Jan 23, 2023 | 03:05 PM
85e150's Avatar
85e150
Rockers are probably ok but you should get springs matched to that setup, and make sure you have the right pushrods as well.
Old Jan 23, 2023 | 04:35 PM
f5fordgirl's Avatar
f5fordgirl
Are the new lifters solid or hyd, if hyd, the rockers will work, if solid, you need rockers for solid lifters, and as 85e150 said.
Old Jan 23, 2023 | 08:42 PM
catastrophejustin
Thanks for the replies. I ordered the springs that are recommended and the tool to measure pushrods. Lifters are hydraulic so it looks like I don't need to get rockers just yet. I got plenty of other things to replace first
wwhite
27
Jun 5, 2020 04:12 PM
jav409
Mar 8, 2006 09:51 PM
ceetwarrior
13
Jun 24, 2004 11:55 PM
averagef250
Mar 5, 2004 06:09 PM
71FoMoCo
Mar 21, 2003 07:21 PM
