Cold Air intake and MAP
Old Jan 21, 2023 | 11:10 AM
azkoyote's Avatar
azkoyote
4wd Low
I recently had some work done on the 91 F150 (5.0) and have a nice open catback exhaust. (also new timing chain and water pump, seals, and other stuff) - The airbox is due to be replaced next and I was thinking of doing a cold air intake mod and getting some K&N pods for it. (the original airbox is, as seems common for the age, cracked and all the bolts are broken and it just sorta sits there with the filter hopefully doing something)
This is way before OBDII, and I have no real idea what's going on with the mass airflow sensor (I'm assuming I have one) or what I may have to tweak. What's my best route forward?
Old Jan 21, 2023 | 11:19 AM
My4Fordtrucks's Avatar
My4Fordtrucks
No mass air flow sensor on that truck from the factory. Your best option is to procure a good used air filter assembly from the junkyard. One modification is to use the intake tube from a 300/460 truck which draws air from behind the grill instead of between the core support and hood.
Old Jan 21, 2023 | 01:57 PM
Mudsport96's Avatar
Mudsport96
This here.
The 460 uses the same airbox and filter. It will flow more than enough for your engine. Just find a good used one.
Old Jan 23, 2023 | 01:01 AM
TexasGuy001's Avatar
TexasGuy001
Yep, you have a MAP sensor but not a MAF sensor. Any KN intake is a waste of money. Just use a stock air box with a normal filter and the 300/460 lower tube.
Old Jan 24, 2023 | 12:17 PM
azkoyote's Avatar
azkoyote
4wd Low
I'm not aware of a K&N intake in my searches for this year and model. What part number is that? I've seen generic pods - which I mentioned replacing the filter units on with K&N - and the's an Banks intake replacement that looks more or less like a sturdier OEM one. (not sure if it includes the actual lower tube) It's about the same price as me finding a really good condition complete assembly at a junkyard.
Do you mean that there *is* a K&N intake - like onvthe mustang forums or something (I know that the answer to this questions would be very different if it was 91 mustang 5.0 because people perceive performance metrics differently)
Or do you mean that the washable K&N filters aren't worth the money?
Old Jan 24, 2023 | 12:20 PM
azkoyote's Avatar
azkoyote
4wd Low
Originally Posted by Mudsport96
This here.
That's a problem. The one junkyard I know has one in the phoenix area seems to always revise their quotes upwards once you have the part in hand (desert valley) and it ends up looking like it's going to be over $200 to redo the box, lid, intake hose. (and that's if I can get them to give me the mounting bolts, which is unlikely)
But it looks like the answer to the question- if I have to spend that much money, is aftermarket worth doing? is no for truck engines.
Old Jan 24, 2023 | 12:59 PM
Mudsport96's Avatar
Mudsport96
Well i went to car-part.com and put in a generic Phoenix zip code and got this list of air boxes.
Im sure one of them can help you
Old Jan 24, 2023 | 08:18 PM
wwhite's Avatar
wwhite
I did a test a while ago, with K&N recharge filter vs fram paper filter, stock air box, 4.9 inlet vs 5.0/5.8 inlet.
I recorded air charge temperature, hp and tq.
The results proved that after market intake on these trucks is a big NO, waste of money that could be better spent.
Stock air box with paper filter, and the 4.9/7.5 intake duct is the BEST.
Then to improve on that, get some reflextic insulation, and wrap the tubes and air box to keep the air colder.
1994 Ford Bronco insulating air box and intake tube pictures, videos, and sounds | SuperMotors.net
Old Jan 25, 2023 | 07:29 PM
azkoyote's Avatar
azkoyote
4wd Low
Well, that's a lot more helpful than calling whatever shows up on maps. thanks!
Old Jan 25, 2023 | 07:30 PM
azkoyote's Avatar
azkoyote
4wd Low
I love data. That's fantastic.
Old Jan 25, 2023 | 08:04 PM
wwhite's Avatar
wwhite
Air flow did not change, the air charge temperature is the factor.
Air temperature vs RPM and HP/TQ vs RPM:
Make a Cold Air Intake from OEM Ford Parts - Page 2 - Ford Truck Enthusiasts Forums (ford-trucks.com)
Old Jan 25, 2023 | 11:33 PM
TexasGuy001
I'm saying anything from KN is a waste of money. There used to be a KN kit for dual air tube speed density trucks that was oval shaped, but I don't know if it has been discontinued or not. I just know that I throw hot air intakes like that in the garbage can. Just get the stock stuff from a salvage yard, eBay, or someone parting out a truck on Craigslist or Marketplace.
Old Jan 26, 2023 | 01:47 AM
wwhite's Avatar
wwhite
For ****z and giggles: K&N 57-2542 FIPK air intake system
Performance Air Intake System (knfilters.com)
Old Jan 26, 2023 | 04:27 PM
azkoyote's Avatar
azkoyote
4wd Low
$800 for a pair? or are you supposed to just hook one side of the intake up? that's ... isnane.
What I was initially looking at, but it doesn't seem to include any actual intake, was the Banks 49216. But that's a lot for a grey plastic cover
https://www.summitracing.com/parts/gbe-49216
Old Jan 26, 2023 | 05:24 PM
Mudsport96's Avatar
Mudsport96
the reason there is no included intake stuff is... it uses all the factory stuff that flows enough for a 460.
