I have an Eaton 23221 rear end with an Eaton Anti Skid control. This was an old fire truck that I'm converting into a wrecker. I cannot find any info on the wheel slip control. Can anyone help?
There is a ton of stuff that seems related but most of it much newer than your truck. That axle comes up with the anti spin, but I can't find anything on the brakes.
Are they Eaton brakes or some other maker?
Brakes are seized. Next warm day I'll jack up and remove drum. With only 10,424 miles I should be able to see some #.s or name. you would think an Eaton rear would have Eaton brakes.
