Need some help finding turn signal hardware. Previous owner had a signal rigged but it has broken. all that i am Looking for is the hardware itself the wiring is in place and should be adaptable for the new hardware. I am already on a 12 volt system.
Also looking for horn for my truck. there is nothing left of a horn if there was one.
Go to NAPA or CarQuest and get a signal Stat brand or equivalent kit. It will probably hook up to what you have for wiring. As far as a horn, get a 12V horn from something late model as you'll burn out the original 6v one. You can even get them from NAPA or CarQuest .
What is a signal Stat? what i need is the parts that actually go on the column with the arm. If that is what you have would appreciate getting it from you.
Your profile seems set to block email communication, so its kinda tough to make 'real' contact. I'll be pullin goff my signal stat clamp on column box and stalk this weekend. I lucked out and found a gool steer box and column with the factory style switch
