Questions Regarding: Big Block Engine (1968) - & - Heavy Duty - ZF - 5 Speed Transmission (1990
Old Jun 4, 1999 | 11:21 AM
John Gilbert's Avatar
John Gilbert
Background:I have a 1990 heavy-duty - ZF - 5 speed transmission designed for a 1990, 460 big-block gas engined F-Series 4 x 4. A friend wants to mate this transmission up to an older, 1968 (??), big-block engine (390 through 460) he claims it is a 460 but I question that and I'm not really sure how to tell the difference from a quick glance. I'm not historically a Ford specialist. All I know for sure is that it is an older big block Ford engine.Questions:What are the comparability problems we will run into when attempting to mate these different vintages of components (i.e., 1968 & 1990)?The older style big block engine has a larger diameter hole in the end of the crankshaft for the transmission input shaft's pilot bearing to slide into to begin with, but we can machine out a new custom pilot bearing to compensate for the difference in the diameter of the newer transmissions input shaft end at the pilot bearing to resolve that problem. This should work shouldn't it?Does anyone know what flywheel comparability problems we might run into? Will the older engine's crank position the flywheel too far back into the belhousing? A crude benchtop measurement suggests that this is the case and that the end mounting surface of the older block's crank sets about .250 of an inch farther back into the bellhousing than is the case for a newer (say 1990) 460 crank. What vintage of flywheel should we use or does it matter. Also, will any specific engine size or year of flywheel resolve this issue of the older crank positioning the flywheel farther back into the bellhousing? Is this really a problem in the first place? What engine displacement and engine year flywheel should we be using for this match up?Does anyone out there know if there is a swap or parts comparability manual published somewhere that can definitively answer all these and other related swap and comparability questions?Does anyone have a Ford parts or Ford SVO contact telephone number and / or contact person I might use to attempt to get answers to these and related questions?I would appreciate any and all advice or leads to a source for answers to these and related questions.Thanks in advance for your help.CheersJohn Gilbert
Old Jun 5, 1999 | 10:06 AM
DAVID DELEON
Guest
Posts: n/a
First you need to determine which motor you have, the 360/390 motors do not have the same trans bolt pattern as a 460. you can tell by checking the heads, the 460 has a normal intake manifold that can be removed by not having to take off the valve covers, the 360/390 motor have the intake mate with the head under the valve cover, so to remove the intake would require you to remove the valve covers, he may also have a 429 motor, this is very simular to a 460 and side by side you cant tell the difference other than by the casting numbers, if he has a 429, the trans will fit.
Old Jun 8, 1999 | 10:24 AM
H8monday's Avatar
H8monday
Try going to www.wrljet.com/engines . This a very informative Ford Engine Website with the history and characteristics of almost every motor Ford has produced.
Jeff,
super@sierratel.com
Old Jun 8, 1999 | 07:41 PM
H8monday's Avatar
H8monday
Its actualy at www.wrljet.com/engines/ .Its a very interesting website.You may also ask your question at the Fordnatics website at
www.chucko.com/fordnatics/index.html . There are some real gear heads on that site,they mostly talk mustangs and road racing,but they loved jumping in and helping with many questions I had durring my F250 build up.Hell,whats not to like about big blocks,(other than maybe gas mileage)? Later,
Jeff
super@sierratel.com
Old Jun 8, 1999 | 10:55 PM
bigtruck's Avatar
bigtruck
Pain
17
Sep 27, 2015 09:07 PM
George Fletcher
Aug 16, 2015 07:01 AM
Gary Lewis
25
May 7, 2012 02:03 PM
jgavac
May 1, 2012 06:50 PM
randall_1
Feb 18, 2001 01:04 AM
