239 French Flathead
Old Jan 18, 2023 | 04:52 AM
Camaronisse's Avatar
Camaronisse
239 French Flathead
239 Flathead. French. Need advice...... i have just take a compression test on the motor....quite even but maby to low readings....warm engine,all plugs out,wide open throttle.....checked the net, should be 110 psi.....at least over 100.... should i change the piston rings?....would it be better when i start using the truck more? was thinking i had a sticky valve in one of the cylinders but now i think it would have showed in one of the readings. The motor stalls and puff a little when pushed.
the motor had been stored for 40years.
Zombie Builder
41
Nov 5, 2021 12:10 PM
Michael D Olear
2009 - 2014 F150
May 20, 2021 05:15 PM
mwhitely1
Oct 5, 2020 04:33 PM
victoryvan
Aug 6, 2020 03:49 PM
PapaBearYuma
Jul 8, 2012 10:03 PM
