PCV Valve
Old Nov 14, 2003 | 11:41 AM
ckite's Avatar
ckite
PCV Valve
I was wondering about the PCV Valve on my 302 the other day and figured that this would be a good place to ask. Where is the PCV Valve located on my 302, truck in sig, and how hard is it to get at and check/change. Thanks for the help.
Old Nov 14, 2003 | 03:57 PM
EPNCSU2006's Avatar
EPNCSU2006
It's in the back of the passenger side valve cover. It's a good reach and will take some wiggling to get it out, but other than that, there's nothing to it. If you get a new one, get it from the dealer, because it will be designed specifically for your application and not just a one-part-fits-all kind of deal that you get in the aftermarket.
Old Nov 18, 2003 | 11:05 AM
siphor84's Avatar
siphor84
Some info you might want to know about the PCV. A lot of people have been redirecting the output because it causes problems the way it comes from the factory. Read through this thread for the details
https://www.ford-trucks.com/forums/s...threadid=15232
Old Nov 18, 2003 | 11:58 AM
EPNCSU2006's Avatar
EPNCSU2006
Good point. Ford moved the vacuum source to the main tree later on in the model run as well. Someone gave me a sheet from Jasper engines that said they had seen many failures in the number 8 cylinder, and showed a way to move it.
brett_d
Aug 31, 2021 02:33 AM
pipeliner83
Apr 27, 2014 04:40 PM
edward r
Jul 21, 2009 10:51 PM
irishman200232
Feb 8, 2004 06:26 AM
reeree
Apr 19, 2001 11:14 PM
