302 PCV Valve
Old Mar 27, 2002 | 03:11 PM
brett_d's Avatar
brett_d
302 PCV Valve
Old May 16, 2002 | 05:09 PM
mcgrew's Avatar
mcgrew
302 PCV Valve
OK. What is the deal with replacing the PCV valve on a 1990 F150 EFI 302 motor? I got the old one out no problem (as it pretty much fell out), but I cannot get the new one in. The grommet alone will go in, but there is no leverage to put the valve in. Do I put them together first and somehow put them in? Or do I have to remove the entire intake manifold assembly to get clear access to the valve cover? What is the trick here?
Sean
:-X11
Old May 16, 2002 | 05:22 PM
amsnss's Avatar
amsnss
302 PCV Valve
Hey,
I have an 89 302 EFI that I have replaced the PCV valve on just recently. It will go in, but takes some persuasion. What I did was connect the line to it first and then put it into the valve cover. It took some work, but it went in
Old May 23, 2002 | 09:42 PM
Groundrunner's Avatar
Groundrunner
302 PCV Valve
I did mine just recently, too, but I didn't have a problem. Is it possible that the wrong grommet was in the box?
Old May 25, 2002 | 12:38 AM
cajunbronco's Avatar
cajunbronco
302 PCV Valve
Hook up the pcv to the tube that goes into the intake.Put a little oil on the bottom of the pcv valve.The grommet should alredy be in the valve cover.Start the pcv in at an angle and push it in.It takes a little wiggling but it should go in.
Billy
Old Aug 29, 2021 | 10:46 PM
Big-Dawg's Avatar
Big-Dawg
302 PCV valve
I had the same issue installing mine. I bought 2 different sized grommets, not knowing which would work, tried to dry fit them & one was too lose, the other too tight. Stupid me decided to ream it out a bit to fit. That worked great before installing it, but after install it leaked oil like crazy. Through trial & error I found out you can throw it in a pot of boiling water to soften the grommet then press in the PCV valve, or install it & run the motor for a bit to heat up the grommet(if you don’t mind hot oil blowing out), then press in the valve. No hydraulic press needed 😂
Old Aug 30, 2021 | 10:52 AM
wwhite's Avatar
wwhite
This must be a new record, 19 years, 3 months, 6 days ago was the last time this post was active.
@Big-Dawg remember to look at previous posts dates before submitting a reply.
Old Aug 30, 2021 | 11:00 AM
Big-Dawg's Avatar
Big-Dawg
wwhite, Sorry about that. Was doing a specific search for my issue & got carried away. 😂😂
Old Aug 31, 2021 | 02:33 AM
TexasGuy001's Avatar
TexasGuy001
This is an ancient thread, but if the info is relevant and someone searches and finds it, then it was still useful to add new info.
1986RedRider
47
Sep 11, 2019 10:25 PM
pipeliner83
Apr 27, 2014 04:40 PM
MrDeath8666
Mar 23, 2003 01:07 AM
mtfl1
Nov 14, 2001 09:04 AM
