Sponsored by: Real Truck
Instrument and speedometerproblem
Old Jan 14, 2023 | 03:11 PM
ShadowDog1949's Avatar
ShadowDog1949
1st Gear
Speedometer drops to zero, sometimes works intermittently, Fuel gauge shows empty(tank just filled) but fuel pump icon comes on as if empty and alternates with Wrench Symbol and the Check Engine light is on. Some times if I shut truck off, upon next start up all works correctly again for varying lengths of time. "Tach" and all other gauges are working, radio works but no display light and all windows and locks work. Also get a Low air pressure notice at time but that is probably a sensor going bad as it has happened on and off before this problem started up(all tire correctly inflated every time that signal comes on) Does any one have and idea of what i should check before I put myself at the mercy of the local Ford Dealer? This is a 5.4 gas Engine.
03redstx
2004 - 2008 F150
Sep 14, 2022 04:40 PM
DinoB
Aug 14, 2022 09:20 AM
Eppidemic
Aug 9, 2020 07:03 PM
87 F-150 I6
Mar 25, 2014 09:37 PM
Benchwrench
Feb 8, 2008 10:06 PM
