F700 Help
I have a 1993 f700, VIN 1FDNF70J8PVA17756.
It was left to me by my grandfather after his passing, so it is sentimental.
In it’s current setup it will redline at about 55mph. I’m trying to find out what transmission and rear diff is in it so I can make some changes and get it to modern highway standards.
Does anyone have any suggestions for how to best achieve this (motor / transmission swap, change out rear diff, etc)
Also, does anyone have anu resources for finding the gears in my transmission and differential? The transmission does not have any visible tags, but the differential has the following:
Meritor
model RS 17220 650
sn AF 659
gear ratio 907
Any help would be appreciated
1FD = Ford Motor Co USA, incomplete vehicle
N = Class 6--19,501-26,000 lbs GVWR, hydraulic brakes
F70 = F700 gas
J = 429 gas V8. (I don't have complete info--EFI or 4V carb--you'll figure it out with a quick glance)
8 = Ignore, Ford check digit
P = 1993 model year
V = Kentucky Truck Plant
A17756 = Serial number
ZA = Diamond white
153 = 153 inch wheelbase
F702 = F700 gas, 24,500 lbs GVWR
8 = This is usually a 3 character code but no upholstery info is given, only body type. This would be standard cab
CM = Eaton model FS-6025-B five speed direct transmission
No axle codes, which is really what we were looking for. This truck was a special order, so the interior and front and rear axle were probably part of that.
87 = Body Company, which would explain in part the special order
0382 = Special Order Number
The axle you have lists itself as Meritor, but I think those were previously Rockwell. The MPC lists a 17220 with a 17,500 lb capacity and 6.50 / 9.07 ratios. Since it seems to be a regular production item, I don't know why it isn't listed.
There are other axles for diesels with taller gears.
What tire is on this truck?
Does the two speed shift into high range?
If this truck has 11R-22.5 tires, those are about 42 inches in diameter.
With that size tire, your direct 5th and the 6.50 high ratio, you should turn 3380 RPM at 65 MPH. The 429 was rated at 235 HP @ 4000 RPM in trucks so it should pull 65 MPH without too much of a complaint.
If you are stuck in Low on the axle at 9.07 you would be at 3990 at 55 MPH and that would be about it as the governed speed would be not much over 4000 RPM.
If you are unfamiliar with these, what is your intended use?
Two speed info here--you have a Rockwell or Meritor axle, but the shifting is the same as an Eaton for the most part. Your axle may be more forgiving but even if it is, never shift it on a down hill. Be in low and stay there.
https://www.ford-trucks.com/forums/1...ml#post9565523
My truck does have 11r 22.5 tires. It also will shift to both high and low. However, in high gear / 5th on the transmission it hits 4K on the tack at 50mph. In low gear it will go about 35 +/-
Was this truck converted to 4 wheel drive? Is there another transmission or anything between the 5 speed and the axle?
50 at 4,000 with a 42 inch tire would require a 10.0 high range.
35 at 4,000 would require a 14.3 low ratio!
The truck is 2wd and there’s nothing but driveshaft between the transmission and rear end. Is there an easy way to check the accuracy of the tach? Just based on feel, it seems like it may be 20% too high.
There are ways to use a multimeter to check them too--but I'd rather find a test tach that shows RPM.
Do a search and you'll see a dizzying array of devices that can test one.
So first, I would ask at a parts store that offers tools and see what you come up with.
Im thinking I am going to make the differential gear ratio more Highway friendly (maybe 3.x high gear and 6.x in low gear. I may also switch out the transmission if I am still getting honked at on the two lane roads.
Thank you all again for your help and time. I have an excavation / pond construction company in Oklahoma. If anyone is in my area I would be happy to offer a steep discount on a new pond to help repay the hospitality on here.
I think you should solve the RPM/MPH mystery first.
You may have a tough time trying to pull a 3.something gear.
These trucks are usually pretty close to RPM/HP limited--in other words, even with a taller gear you can't go much faster due to drag and rolling resistance.
Read through the thread--his tach must be way off.
