1995 7.3 Rough Idle SOLVED
Old Jan 12, 2023 | 06:12 PM
Dylan1598's Avatar
Dylan1598
Trailering
below is what I was experiencing. What solved the problem was new ICP
I will include as much info as I know. I got this truck 2 days ago. Truck had a edge 6 position tuner on it which I ran with for the first couple days but I could tell there was some idle issue. On a cold start the check engine light would be on but it would go off once the truck was warm but still seemed like it had a rough shake. I pulled valve covers off to see if all injectors were working and all 8 were spitting and I unplugged 1 at a time so i could tell each one was working. At this point I decided to remove the edge 6 position tuner and well that seems to make the idle even worse (videos included) idk if the tuner was masking the issue best it could or what. I have included 2 videos both of which have the 6 position tuner OFF the truck. one video you will notice where the check engine light is on and once it goes off the truck has a big hiccup and goes back to idle but idles pretty rough. I can press on the pedal and it levels out but once I release its right back to rough idle. all help would be greatly appreciated. I was thinking bad injector or worn injectors but they all fire and it was running better with tuner on it but still not perfect so I hate to go spend over a grand on something that might not fix the issue
File Type: mp4
File Type: mp4
Old Jan 12, 2023 | 07:31 PM
McLe's Avatar
McLe
Maybe low fuel pressure at idle? Once revved, it bumps it up a bit?
Old Jan 12, 2023 | 07:52 PM
Dylan1598's Avatar
Dylan1598
Trailering
when I rev it it seems smooth
Old Jan 12, 2023 | 08:09 PM
Action4478's Avatar
Action4478
You need the least amount of FP at Idle . The truck will run on 10 PSI . Most likely have an HP oil pressure leak. Check the IPR first . A good scanner for data will help .
Old Jan 13, 2023 | 01:45 AM
McLe's Avatar
McLe
Think a quick check of fuel pressure would make sense. Those lift pumps are not great. Atleast they're cheap.
Old Jan 13, 2023 | 06:41 AM
Dylan1598's Avatar
Dylan1598
Trailering
don’t believe it’s a hpop I don’t see any oil and the truck fires up no hesitation
Old Jan 13, 2023 | 07:46 AM
Bitterroot Diesel's Avatar
Bitterroot Diesel
Former Vendor
How many miles on injectors? Most sellers don't do all the PM then sell.
Old Jan 13, 2023 | 07:52 AM
Dylan1598's Avatar
Dylan1598
Trailering
I’m not sure of the mileage on injectors
Old Jan 13, 2023 | 07:55 AM
Dylan1598's Avatar
Dylan1598
Trailering
Upon more inspection I’m going to be replacing the icp today. Pulled the plug this morning and the inside the plug is wet and the whole sensor is covered in oil. I’ll update y’all once I change it.
Old Jan 13, 2023 | 07:56 AM
Bitterroot Diesel
Former Vendor
How many miles on the truck?
Old Jan 13, 2023 | 07:58 AM
Dylan1598's Avatar
Dylan1598
Trailering
truck has 245k on the clock
Old Jan 13, 2023 | 08:01 AM
Bitterroot Diesel
Former Vendor
I'd bet they are original and they are due for replacement.
Old Jan 13, 2023 | 08:08 AM
Dylan1598's Avatar
Dylan1598
Trailering
you are probably right but I’m not looking to spend that kinda money right now. I know all injectors are working due to pulling valve covers and checking so ima try and ride them for a bit. Gonna start with that icp sensor today. Truck only has check engine light and rough idle when it’s cold. Once it warms up check engine light goes away and idle smooths out
Old Jan 13, 2023 | 08:10 AM
Bitterroot Diesel
Former Vendor
Oil coming out of the port won't tell you how bad the injectors are
Old Jan 13, 2023 | 08:12 AM
Dylan1598's Avatar
Dylan1598
Trailering
I agree just weird after warm up the truck runs great
