I would like to replace the squirters on the windshield wipers, and didn't find a cross for any number that shows this part number - it's a 1989 3.0L Im sure it was used on lots of stuff back in the day.
the tubes are all still fine, the nozzles are what I need - the driver side is fine, but the passinger side is squirting a solid line over the windshield! so it must have lost the "spray" element inside of that unit?
anyways any help with where to get them or a link would be great!
if you mean the two spray nipples attached to the plastic grille, you could try and adapt other types of squirters, there are many styles with twin adjustable up / down / sideways squirters.
The original Aerostar fittings are a really bad design, once they clog, no way to fix them or find new replacements.
A trip to a junkyard will locate something suitable and adaptable.
