Windshield trim clips
Old Jan 9, 2023 | 10:10 AM
chesster51's Avatar
chesster51
The clips on the bottom of my windshield that the molding attaches to are rusted away and nothing left for the molding to clip to. I bought new clips to replace the old rusted ones. My truck has the double clips that are attached with two rivets. There does not seem to be enough room under the glass to drill out the old rivets and the windshield will have to be removed first. Is this a DIY job or should I have an auto glass shop do it? If DIY, how hard is it? Thanks in advance, Rick
Old Jan 9, 2023 | 10:24 AM
Encho's Avatar
Encho
The Southernmost Mod
Maybe a couple of pictures would make your problem clear for others to chime in. I think you're talking about the clip at the base of the wiper's arm. If that's so, maybe you can get away with removing the cover (body part) and mayyyybe the hood, if it's in the way.
Old Jan 9, 2023 | 11:53 AM
chesster51's Avatar
chesster51
Doesn't seem to be possible w/o windshield removal
Old Jan 9, 2023 | 01:25 PM
Fordication's Avatar
Fordication
Yes. I would remove that windshield and attack the corrosion before I did anything else. As for the rivets, they are replaced with a set of screws you can buy on most collector car websites. You just drill a small hole and screw the screws in place of the rivets.
Old Jan 16, 2023 | 05:28 PM
Encho's Avatar
Encho
Yep, you won't be able to get all that rust without removing the windshield.
DavenTn
Sep 23, 2019 03:15 PM
GoldCo
Jul 24, 2017 02:57 PM
CUSTOMIMAGING805
Apr 14, 2011 05:10 PM
51phil
Apr 2, 2011 01:23 AM
gtex
13
Nov 19, 2002 07:10 PM
