Rear frame crossmembers compatability
Old Jan 9, 2023 | 08:55 AM
idealtrucks's Avatar
idealtrucks
I'm needing two rear crossmembers in from of the rear gas tank and also the shock mounts.
From looking at pictures they look very similar to the 92-96 bodystyle. There are some good, very easy to get to frames in my local junkyard of that model. Does anyone know if they are compatible with my 78 frame?
Old Jan 9, 2023 | 09:24 AM
speedfreak78's Avatar
speedfreak78
They're probably the closest that could be made to work from what I've seen. Have you looked on ebay? I see dentside crossmembers pop up there often, mine are rotted out too. The shock mounts are different, yours should be a stud mount top and the OBS trucks use an eyelet mount up top.
Old Jan 9, 2023 | 10:28 AM
idealtrucks
I've checked ebay. They are much pricier than I can get local for though.
ryans88gt
37
Dec 23, 2013 05:24 PM
fred_79f250
Aug 5, 2006 01:30 AM
learpilot
Dec 16, 2004 07:17 AM
gdavis2265
Jun 4, 2003 11:13 AM
Highboy70
Jul 26, 2002 04:49 PM
