Code P2033
Old Jan 6, 2023 | 05:58 PM
pabear89's Avatar
pabear89
Code P2033
Have 21 f250 6.7 that has less than 10k miles and it has check engine light with code p2033 using scan tool.
Dealer says earliest they can check it is Jan 24th and I need to use my truck.
Searching at NAPA and they show no replacement part, But Rock Auto has part # ets 226 replacement senser.
Will it harm anything to drive it before I can get it to dealer for warranty work?
Or should I just get the replacement part and fix it.
Old Jan 6, 2023 | 06:02 PM
senix's Avatar
senix
your only issue is if it does not come out easy. Need a scan tool to erase the code after the new sensor is in.
Old Jan 11, 2023 | 03:19 PM
pabear89's Avatar
pabear89
Gettting it to unplug from harness was harder than removing it from the pipe.
Looking at it seems to be ok, Is there some way of testing it?
Still trying to figure out why it toss code or what could have caused it to go bad with so few miles.
For now its the wait for the mailbox delivery.
Old Jan 11, 2023 | 07:05 PM
senix's Avatar
senix
just how many ohms it should read good vs bad would be my assumption. probably would need the tech specs on it which I don't have.
Old Jan 19, 2023 | 02:48 PM
pabear89's Avatar
pabear89
Mail came with new part, Test ohms are 220-230.
old part shows 0
Cleared code now will test drive this weekend. tks
SCarolina
6.2L V8
Aug 28, 2020 07:03 PM
Rigdawg
6.7L Power Stroke Diesel
May 1, 2018 07:34 AM
basecamp
EcoBoost (all engine sizes)
May 14, 2014 08:51 AM
don77
Jan 16, 2010 09:21 AM
dieselman2000
Feb 17, 2007 03:33 PM
