Excursion 4WD rear differential rumble?
Old Jan 6, 2023 | 08:18 AM
jattura's Avatar
jattura
6th Gear
Ok, I need some help from you guys. I have a 2000 Excursion Limited 4WD with the V10 and 100,000 miles. Drivetrain is original. The problem: From a dead stop, when I make a turn at very low speed, I’m getting a distinct rumble noise and vibration from something out back. I assume it’s the rear diff. It sounds and feels bad, like I’m damaging something. Once my speed is above 15 - 20 mph it goes away. There is no noise or vibration at highway speeds. I didn’t notice the problem until my Ford dealer changed the differential fluid. I brought it back to them to make sure they didn’t forget to refill the differential, but they said it’s full. Any thoughts? Thx.
Old Jan 6, 2023 | 09:52 AM
Dweber85rc's Avatar
Dweber85rc
Check your read driveshaft ujoints for play, check the driveshaft slipyoke/splines for play, check the pinion flange for play.
Old Jan 6, 2023 | 12:01 PM
pirate4x4_camo's Avatar
pirate4x4_camo
FTE Remembers
If the noise only happens when you are turning I would suspect a loose wheel bearing
Old Jan 6, 2023 | 06:37 PM
jattura's Avatar
jattura
6th Gear
Thanks Dweber. I’ll have all that checked.
Old Jan 6, 2023 | 06:38 PM
jattura's Avatar
jattura
6th Gear
Interesting thought. I’ll check that. Thanks.
Old Jan 7, 2023 | 11:34 AM
Zouri's Avatar
Zouri
1st Gear
I believe, before I changed my pinion seal, I had to add some diff. fluid, and added a ford supplement that would help the posilock rear end slip while cornering.
If you used ford diff. fluid, it may have had the additive already in it.
srauner
Jul 2, 2016 12:44 PM
gogreenwave
Jul 30, 2014 05:54 AM
ldgrate
Dec 31, 2003 05:24 PM
radar_ridr
Feb 18, 2003 06:55 PM
