Loose shift/signal column
Old Jan 5, 2023 | 05:09 PM
dlatourette's Avatar
dlatourette
Trailering
I've searched, but I don't know the proper terminology for what I'm looking for My 2019 F350 SD has a slightly loose column clamp or sleeve. When I operate the shift lever, the entire assembly rotates slightly with it. I've removed the upper and lower shrouds, but I am not seeing a setscrew or clamp to tighten to eliminate this problem. Do you have any ideas, or an exploded diagram that might show where the fastener is? Thanks!
Dave
Old Jan 5, 2023 | 05:22 PM
morehouse7's Avatar
morehouse7
Not sure if this helps, some views of the assembly in there.
https://www.ford-trucks.com/forums/1...-problems.html
Old Jan 5, 2023 | 05:27 PM
dlatourette
Trailering
Thanks. The piece that rotates on mine is the most outboard casting in the second image in that thread - the one the shifter mounts to and the turn/light stalk mounts to. I just can't see any clamp bolt(s) or set-screws to anchor it to the rest of the column.
PapaMatt
Mar 19, 2015 07:17 PM
62Ahkbar
May 3, 2012 09:15 AM
TimRob
1983 - 2012 Ranger & B-Series
Aug 18, 2005 08:02 PM
manning
May 16, 2002 09:12 PM
