Parts Options
Parts Options
97 F350 XLT 2WD
First time F350 owner. Truck is in great shape just needs some minor updates. Not having any luck finding some simple parts online. Any recommendations on sites, stores to search?
Looking for oem style parts:
Exterior side trim/moldings
Inside door seals (air dam)
Mirrors
Also looking to go up in tire size but can’t find any suspension lifts online. Trying to fit some 315/75s with the factory 16 wheels. Looking for a simple 3-4 inch lift. Or what is the biggest tires I could fit with factory height. Thank y’all!
Mirrors
35s will fit if you cut the font bumper a ili in fender area or add 2 in spacer for bumper then makes a nicer step stool
on tight turns the tire will rub the leafs a lil depending on rim depth but heard a 1/2 in spacer works well to address this
not sure what frond end type you have with 2wd and what setup you have in rear
i like to use this site for lift stuff
https://www.pmfsuspension.com/1988-1...0350_c_11.html
I usually go to LMC Truck and Bronco Graveyard. Look in their "92-96" areas. Just about all the body stuff is the same as the 150's, and they have the 250/350 specific items also.
I moved my front bumper forward 2" even though I'm running stock size tires.
CountryBumkin
May 11, 2012 11:18 AM
adam 1997 F350 7.3
Sep 7, 2011 10:43 AM
