Bronco II Ford Bronco II
charging system
Old Nov 13, 2003 | 10:28 PM
fordbidden dreams's Avatar
fordbidden dreams
Angry charging system
ok i have the worst luck with alternators. heres the deal. i got the bronco and the system was working good. i put in a stereo system with the correct power caps to protect the system. but slowly the the voltage reading went down. at idle it would be 12.5 at the most and sometimes 11.5. if i would rev the motor it would go up to 14.1 but never higher. i picked up a new alternator and had it bench tested and it was reading at 14.5 put it in the truck and the charging system never read over 14. now its doing the same thing and dropping to 12.5 at idle and never going over 13.9 when i bring the rpms up. would this be a nother bad alternator???
Old Nov 13, 2003 | 10:54 PM
rallybronco's Avatar
rallybronco
i have a stock alternator in my 86 bronco 2 but puts well over 14 at idle and about 15.6-9 at rev. but for a stereo all i have is a ghetto pyramid cd player
Old Nov 13, 2003 | 10:58 PM
rallybronco
have you made sure that your belts are nice and tight?
Old Nov 13, 2003 | 11:03 PM
fordbidden dreams
yes, the belt is tight and new.
Old Nov 14, 2003 | 12:44 AM
pat67shorty's Avatar
pat67shorty
What year is is? 84/5 or an 86-up? I would suspect the regulator.
Take the caps out of your system and see if it improves. If the caps drain faster than they can charge, they are just a drain on your electrical system.
Old Nov 14, 2003 | 01:11 PM
fordbidden dreams
its a 90, and has a built in regulator on the alternator
Old Nov 14, 2003 | 07:52 PM
MJB's Avatar
MJB
You may have an alternator with too low amperage. 60 amp is normal for our BII's but adding more load to the system will cause you to buy a more powerful alternator. Look at 125 amp alternators.
ghuns
Apr 14, 2019 07:25 AM
pdqford
Electrical Systems/Wiring
17
Apr 7, 2015 04:20 PM
Restlesswildman
Feb 3, 2013 08:00 PM
mfm1978
2004 - 2008 F150
Feb 12, 2012 05:55 PM
idgcorp
Jul 24, 2004 11:02 PM
