Sponsored by: Real Truck
6.0 fuel problems.
Old Jan 3, 2023 | 05:21 PM
LaneDeal's Avatar
LaneDeal
4wd Low
6.0 fuel problems.
I have a 2006 f250 with the 6.0 in it. Bought it about a year ago, and put new warren diesel injectors 190/30cc injectors in it maybe 5 months ago. I had a problem where over 3k rpm’s it would run out of fuel and loose power, with a fuel knock. Recently I put a new air dog system on it hoping it would improve my fuel issue. It helped but still runs out of fuel and fuel knocks until I turn it off and prime it, then it is fine. Has had some hot start issues but never not started. Could it be my hpop? Also has a regulated return kit on it. If anyone could help or have any ideas about it that would be great.
Old Jan 4, 2023 | 07:02 AM
99powerstrokedF250's Avatar
99powerstrokedF250
Might want to check to see what kind of fuel pressure you're getting from the fuel pumps - one or both could be weak and causing most of your issues. It could POSSIBLY be your HPOP but if you aren't getting enough fuel I'd start with how the fuel gets delivered.
Old Jan 4, 2023 | 06:43 PM
LaneDeal's Avatar
LaneDeal
4wd Low
the new airdog is running at 58 psi. The hot start issues I have sometimes leads me to believe it could be the hpop but I am still unsure
Ed Motta
Jan 9, 2022 09:54 PM
Chuckymccabe
Dec 23, 2020 09:05 AM
erichy
19
Jul 17, 2011 01:26 PM
fullthrottle9393
Nov 17, 2009 05:19 PM
olfordsnstone
May 30, 2005 07:44 PM
