speedometer driven gear set
Old Dec 31, 2022 | 11:14 AM
robe's Avatar
robe
Trailering
Question speedometer driven gear set
Hello all. I know this has been addressed in an earlier thread but.... my 64 F-100, 2 wheel drive with the T-98 four speed needs a 17 tooth speedo driven gear. This part is all steel approximately 3 1/4 inches long. I had the speedo head repaired and supposedly re-calibrated by a local reputable long time in business shop. Now it registers about 5mph slow, so I would like to swap my 18 tooth gear for a 17 tooth gear. Does anyone know of some obsolete trans. parts sources? My source has since closed up shop (Valley Gear) up in Washington state.
Thanks in advance for any clues.
Old Dec 31, 2022 | 11:47 AM
Crop Duster's Avatar
Crop Duster
Read thru this thread. In post #8 ND gives some PN's for the gears for a T98.
1964 f100 t18 4speed metal speedometer gear, speeedometer inacurate - Ford Truck Enthusiasts Forums (ford-trucks.com)
Old Jan 1, 2023 | 01:53 PM
robe's Avatar
robe
Trailering
Thanks for redirecting me down to ND's earlier post. From his information it appears I am out of luck for a 17 tooth type 5 driven gear as they appear to only range from 18 through 21 tooth. (currently running the 18 tooth).
He also stated that there were 3 different drive gears (6, 7, and 8 tooth count), I wonder if changing them to less teeth would solve my problem; or it might be too much of a ratio change and really mess with the accuracy??
Disappointed that the speedo shop couldn't dial this in a little better after 3 trips. Needle is smooth and ODO functions, just 5mph slow, however.
Will do for now as I pretty much know what 35, 40, 45 mph feels like by the seat of pants driving; and I also have a speedo app on the phone for going through photo radar areas.
Thanks again for the reply, Happy New Year!
Chris
Zachthemoo2
Oct 2, 2014 04:42 PM
PetesPonies
Jun 2, 2010 11:04 PM
jas88
Jun 24, 2007 05:42 PM
Andysutt
Feb 17, 2004 09:44 AM
mikeelikee
Jan 23, 2004 09:14 PM
