Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Valve Cover Gaskets
Old Dec 28, 2022 | 08:18 PM
Lariat 86's Avatar
Lariat 86
Valve Cover Gaskets
I have a 06 escape XLT 4wd with 3.0 that had developed a big oil leak onto the exhaust on the back side of the engine. I already have the valve cover off, cleaned up, and ready to go back on. I was wondering if there is anything I should be on the lookout for or any tips before putting everything back together tomorrow.
Old Dec 29, 2022 | 10:55 AM
scott91370's Avatar
scott91370
If you're that far in you might do the spark plugs.
Old Dec 29, 2022 | 01:43 PM
projectSHO89's Avatar
projectSHO89
Don't forget the dabs of RTV gasket sealer at the specified locations.
Old Dec 29, 2022 | 02:45 PM
Lariat 86's Avatar
Lariat 86
Thanks for the replies. I got the Felpro gasket set VS50579R from O’Reilly’s. My old gasket had gotten hard like plastic so I changed not only the valve cover gasket but the 3 for the spark plugs and the ones on the bolts also. I did add some RTV where the head and timing cover comes together. I also replaced all the spark plugs as well. I’m thinking now that I’m finished I probably should’ve replaced the PVC while I was in there. I had a hard time finding the torque sequence for the valve cover and upper intake but I finally found them. Hopefully they was correct.
Montag
Feb 4, 2019 01:07 AM
ford66
Aug 9, 2009 08:54 PM
83maverickf-100
May 26, 2008 09:15 PM
reefdiverbob
Jun 10, 2006 10:55 PM
bigpumpkin
Sep 17, 2002 10:06 PM
