help !
Old Dec 28, 2022 | 07:55 PM
buzzinduzzin's Avatar
buzzinduzzin
help !
1978 F-250 4X4 front lockout hubs : the grease that I use on the lockout mechanism sliding components is way too stiff in cold weather & hubs won't engage !! what do you guys use or recommend ? TIA
Old Dec 28, 2022 | 11:59 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
You can take the lock in/out off and spray it with brake cleaner to get some of the froze grease off. Then put it back together with a very light coat of grease, do not pack the grease in there. Also make sure that the grease is the problem and not some other new issue. Do not take it apart to the point you are pulling wheel bearings, just the lock in/out.
Old Dec 29, 2022 | 08:09 AM
speedfreak78's Avatar
speedfreak78
I've always packed em with whatever grease I'm using on the bearings. They get a little sticky when it gets cold, but if you work them regularly over the year they aren't that bad. The synthetic grease seems to be a little better in the cold.
They also sell a tool that's just a big plastic **** with lugs that makes it alot easier.
https://www.google.com/search?q=ford...=firefox-b-1-d
Old Dec 29, 2022 | 09:40 AM
440 sixpack's Avatar
440 sixpack
Depends on what hubs you have. most of the Warn style just uses 80w-90 oil.
Just put them in and leave them until the weather gets better it's not going to hurt anything.
Old Dec 29, 2022 | 10:45 AM
77&79F250's Avatar
77&79F250
So I just found this....."Never use wheel bearing grease in locking hubs,...and do not "pack" the locking hubs with grease of any type.
When servicing locking hubs, I "paint" all moving locking hub parts with white lithium grease with a "throw away" acid brush.
When installing the locking hub to the wheel hub, I pour in 2-3 ounces of clean engine oil (10W-30 is fine) to keep the hub lubricated and protected from corrosion.
Lock the hubs once a month and drive it several miles (or all day) to keep the lube circulated.
Never had trouble with hubs after doing this for 40 years."
So now I am going to go re-read my OEM shop manual.
Old Dec 29, 2022 | 10:54 AM
Mark8man's Avatar
Mark8man
I've been using Kendall L-427 Super Blue for hubs and just about everything related auto/truck/off road equipment, and definitely on any severe duty applications with temperature extremes. Good from -40 to 350 degrees F
Old Dec 29, 2022 | 11:10 AM
77&79F250's Avatar
77&79F250
Appreciate the heads up on this stuff. https://kendallmotoroil.com/product/...er-blu-grease/
Old Dec 29, 2022 | 01:40 PM
tbear853's Avatar
tbear853
My hubs get exactly the same grease as my front wheel bearings as there is no partition between them. If I put oil in them hubs, then I'll have oil in them bearings too. I use only Moly fortified Ford disc brake spec Valvoline grease, VV632. It works.
I made me a **** to turn the red hub ****, but I like that fancy blue one. It really is easier than finger tips in ice filled cold recesses. An internal spring "locks" the hub, the red **** only uses ramps to push the lock ring apart to unlock the hub. When locking hubs, the ramps just move so the spring can push the lock ring into engagement.
Old Dec 29, 2022 | 05:20 PM
Old Guy F-250's Avatar
Old Guy F-250
Tbear,
Like you that is all I have EVER put on locking hubs. Never had any issues.
Same grease as the bearings. Although very little.
Alex
Old Dec 29, 2022 | 06:53 PM
stpackard's Avatar
stpackard
I have found disengaging 4wd helps before turning hubs to free, drivetrain bind would not help. I used the Parker o-ring lube for the sealing o-rings, it might cause them to operate smoother and not tear up the rubber rings. The dana service manual for locking hubs said to use that so I figured to give it a try.
Old Dec 29, 2022 | 06:56 PM
440 sixpack
You should use grease on the bearings and oil on a Warn style hub. Warn tells you to do this. it doesn't matter if there's a no divider the grease stays where you put it and the Warn hub only takes a coating of oil it's not in an oil bath.
On Spicer hubs when we had the ranch fleet I used 80-90 on them too , all you have to do it give them enough lube to slide back and forth. now days that they're my toys I go ahead and use a little grease I don't care about cold weather I never engage them anyway. .
Old Dec 29, 2022 | 07:11 PM
77&79F250's Avatar
77&79F250
Yes you should put the truck (xfer case) in 2wd before you try to unlock the hubs. Just like the owners manual tells you to do. Also if you have difficulty shifting out of 4wd, you can try backing up a few feet to help un load the drive line.
Old Dec 29, 2022 | 07:16 PM
tbear853's Avatar
tbear853
Absolutely, I never try to unlock hubs unless the transfer case is in 2-HI. To try that with a load on them is how the fingers that ride the ramps get bent or broke. You can lock hubs anytime, as until you lock them there's no load on the ramps or fingers, just the spring pushing the locker ring to engagement.
Old Dec 29, 2022 | 09:13 PM
wyrm73's Avatar
wyrm73
At first I was like, "Thanks- yet another tool that I 'have' to buy now that I know it exists." And then I remembered that I have a 3D printer...
Old Dec 29, 2022 | 09:22 PM
77&79F250's Avatar
77&79F250
And if you do not maintain then hubs properly here is how they can look. When you do NOT have that tool, or use the wrong tool a bunch of times.
