Aerostar Ford Aerostar
coolant leak
Old Jul 16, 2023 | 03:34 AM
xlt4wd90's Avatar
xlt4wd90
Well, I may have to rethink this, as I found some pretty serious water damage in cylinder 6. It seems water has been leaking into it for a while and each time I parked, water accumulated, and seemed to have corroded the cylinder wall. The other cylinders look fine.
If I ignored this and just ran it, I'm sure it's just going to blow-by and send more crud into the crank case.
But fixing it means having it bored out significantly, and having the whole engine rebuilt. But before that, I'll have to pull the engine, through the front, as dropping it down the bottom means dropping the cross-member with all the suspension bits. Argh!!!
Not sure where I can get a rebuilt short block.
Old Jul 16, 2023 | 03:42 PM
85e150's Avatar
85e150
Strong chance of a weak cylinder and an oil burner......
Old Jul 17, 2023 | 10:21 AM
xlt4wd90's Avatar
xlt4wd90
I knew about the oil burning. It's probably the cause of all the sludge I found in the bottom of the oil pan.
Time to start looking for a machine shop, and maybe a used block.
Old Jul 18, 2023 | 12:13 PM
xlt4wd90's Avatar
xlt4wd90
Is the only way to determine if the block is still usable to bore it out to its limit, and see if the defects can be machined out? Or can measurements be taken somehow to see if it's worth even trying?
Old Jul 19, 2023 | 08:44 AM
Kruse's Avatar
Kruse
A good machinist can probably look at your block and tell you how much needs to be taken out before it happens. Usually. However, have you priced oversized pistons for the Aerostar lately? I guess I could say it about anything, but oversize 4.0 pistons are expensive. And I've also had some machinists bore a block out to where a larger oversized piston will work, but then tell me that he can't find rings for that size. (That was fun....finding oversized rings from some mom-and-pop shop in California that hadn't been touched for a few decades) Anyway, before you get deep into this project, budget how much you are willing to pay and if all parts are available ahead of time.
Old Jul 19, 2023 | 08:46 PM
xlt4wd90's Avatar
xlt4wd90
As it turns out, Rockauto has a couple choices of oversized pistons, either as just a set of 6 for about $97, or part of a rebuild kit for about $290. They're made by Engine Tech (any good?).
Old Jul 22, 2023 | 07:20 AM
Kruse's Avatar
Kruse
I would have no problem using that brand, especially since this isn't an engine that will ever be revving at 6K. But I'd probably use a set of rings that have a better reputation. As far as their gaskets set, buy Motorcraft (if available), FelPro or Victor Reinz. I've seen the EngineTech brand missing some necessary pieces on their engine overhaul kits. My $.02.
Old Jul 22, 2023 | 12:02 PM
xlt4wd90's Avatar
xlt4wd90
Thanks Mr. Kruse.
My local engine builder will be shopping his own parts, so I don't know what brand he will be getting.
Old Jul 22, 2023 | 01:10 PM
RojoStar's Avatar
RojoStar
Fyi for the audience, within LA / Orange County / SoCal, there is no lack of options.
Long after legacy aerospace quit out of here in the mid 70's, a half dozen piston manufacturers are at your service, you decide the spec.
You only need to bring a check book.
I will conjecture that a set of bespoke with rings to be in the $800 range.
Not my strategy, I would recommend procuring a rebuilt and be done with it, and that is exactly what I did in engine #2 out of 3. $1700 iirc.
On the other hand...
In #4 To Be Decided TBD, I'll be buying bespoke pistons sohc 4L, cost absolutely unimportant to this hobbyist.
Old Jul 22, 2023 | 02:48 PM
xlt4wd90's Avatar
xlt4wd90
I'm sure if cost were no object, and I was building a suped up power house, I would probably do that EcoBoost 2.3L transplant. That would give about double the power of the 4.0 v6, and maybe 100+ lbft of added torque.
But now, all I want to do is to fix the engine reliably at as low cost as possible. The local machinist says he can do the whole thing for about $1200. I've use him before, and he did great work each time.
I haven't found a rebuilt for the price you quoted. Can you share?
I am tempted to add Tom Morana's valve train, with the 1.8:1 rockers. He claims an increase of 25hp, at a cost of about $1000.
Old Jul 22, 2023 | 03:10 PM
RojoStar's Avatar
RojoStar
... the price you quoted. Can you share?...
A Vulcan, ->15+ yrs ago.
Old Jul 22, 2023 | 07:39 PM
xlt4wd90's Avatar
xlt4wd90
Well, the current prices for a rebuilt 4.0 v6 is probably +1000 more. That's probably using rebuilt stock heads, that have the weak castings that are prone to cracks, like mine.
If my block is usable, I'll have it rebuilt.
Old Sep 11, 2023 | 05:51 PM
  #28
xlt4wd90's Avatar
xlt4wd90
After a bit of messing around, I finally got into the engine. It stared with the tell-tale signs of coolant leakage on the outside:
https://photos.google.com/share/AF1Q...Zycm5RNTZTeWZB
leading to a long journey of removing the heads to find more leakage and damage, then the removal and overhaul of the short block. I'm slowly re-assembling the engine, and maybe ready to re-install this weekend.
The engine pictures are interspersed with pictures from the auto to manual conversion. Maybe I'll create separate albums some day.
BF1956
Apr 27, 2020 07:07 PM
weyland426
6.4L Power Stroke Diesel
Aug 9, 2017 06:24 PM
waituntilthebeep
Sep 8, 2016 03:31 PM
traviswx1
May 25, 2012 12:41 AM
kylemay
1978 - 1996 Big Bronco
Sep 2, 2003 09:40 PM
