how fast am i going
Old Nov 16, 2003 | 03:25 AM
  #31
Mike W's Avatar
Mike W
Hi NM5K, I am a fellow Ham. I run a little higher power at work, 250 KW.
Old Nov 16, 2003 | 05:13 PM
  #32
eangel's Avatar
eangel
Willowbilly is right - I measured my tire diameter and it was 28.1" instead of the 28.9" calculated by the Excel spreadsheet. I plugged this in and got 61.4 MPH at 2800 RPM, pretty much what my speedo says, so assuming my tach is accurate the formulas work pretty well.
The calculators NM5K mentions sound better but this one seems not too bad.
If you want to use a measured tire dia. in the Excel calculator just replace the value in cell B15 with whatever you measure. I'd copy and paste the formula in B15 first to another cell at the bottom of the spreadsheet and update the cell addresses (they change when you copy and paste) so that you've still got a record of it.
To get an MPH for any RPM you want, just pick another cell at the bottom of the spreadsheet and enter the formula =B18*[RPM/1000]. You can enter the RPM directly in this formula or enter it in another cell and have the formula reference that cell location.
Opiewan, I assume you're using the downloaded version of the Excel spreadsheet - that way you can make whatever changes you like and save them.
Old Nov 16, 2003 | 09:35 PM
  #33
Opiewan's Avatar
Opiewan
hell now i cant even get the damn thing to work lol. can you email me the one you got ? i can change the tire values and gear ratios myself. i should learn more about these damn things
Old Nov 17, 2003 | 04:21 AM
  #34
willowbilly3's Avatar
willowbilly3
Thr basic formula is simple, Just do the math yourself. Determine the diameter of your tire and use the gear ratio to figure out how many times it goes around in a mile. you have to convert miles to inches. Example. 3.55 gears and a 29 inch tall tire. Multiply 29 times pi (3.14) to get diameter,( or measure around your tire for a more accurate measurement) hence 91.06, 91 is close enough. Turn miles into inches, 5280 x 12=63360. divide tire diameter into that. 63360 divided by 91=696.26 tire revolutions per mile. Multiply that times the gear ratio. 696.26 times 3.55= 2471.723 which would be your rpm at 60 mph. take it further and divide 2472(rounded off) by 60=41.2 revolutions per mph. Now you can just multiply whatever mph you want by 41.2 and get your rpm at any given speed. These figures are for a 1:1 high gear. If you need to know the rpms for a different gear just multiple the rpm times the ratio of the gear. For instance if you had overdrive with a .80 ratio you would be turning 1977.6 rpms at 60 mph. It's all just simple math.
Old Nov 17, 2003 | 05:50 AM
  #35
Opiewan's Avatar
Opiewan
okay i got it now. thanks
Psycho_bob_1977
249
Nov 18, 2019 08:34 PM
73stang
Mar 6, 2016 03:07 AM
TCAS007
2009 - 2014 F150
16
Aug 21, 2015 11:15 AM
2001 5.4 Supercrew
1997 - 2003 F150
Dec 8, 2010 11:09 PM
metalmilitia
Jan 12, 2004 08:50 PM
