Adding Electrical Accessories
Old Dec 28, 2022 | 11:20 AM
CT-Mike's Avatar
CT-Mike
I will be installing a VIAIR 485C dual compressor OBA system, along with a Victron TR 12/12-30 Smart Isolated DC-DC charger to charge the 5th wheel batteries on travel days. What should I use to make the connections to the positive terminal of the batteries?
Additionally, the truck has dual batteries, does it matter which positive terminal I connect to?
Thanks
Old Dec 28, 2022 | 01:33 PM
chadstickpoindexter's Avatar
chadstickpoindexter
The positive terminal on the passenger side battery has a post you can use (on my 22 6.7). As for ground I would just use the closest grounding point on the chassis.
Old Dec 29, 2022 | 07:00 AM
IADiver's Avatar
IADiver
I purchased a terminal block and will attach it to the post as Chad stated. I will feed a couple of different items from that.
Old Dec 29, 2022 | 08:27 PM
traveldawg's Avatar
traveldawg
Grounding to the chassis is a good idea. Otherwise if you go directly to the battery ground you want to be sure to run your ground through the sensor that measures amps used from the battery. It's on the PS battery ground wire.
Old Dec 30, 2022 | 05:26 AM
CT-Mike's Avatar
CT-Mike
Happen to have a link for the terminal block you used?
Old Dec 30, 2022 | 07:06 AM
IADiver's Avatar
IADiver
I have not installed yet, but this is what I ordered.
Amazon Amazon
Old Dec 30, 2022 | 09:40 AM
CT-Mike's Avatar
CT-Mike
https://www.amazon.com/dp/B08PCGFX3L...roduct_details
That seems like a nice solution, but I’m not sure that it would accept the 4 AWG wire that I need to power the VIAIR and the DC-DC charger.
Old Dec 30, 2022 | 12:10 PM
Leardriver's Avatar
Leardriver
I just wired an E locker on my Wrangler two days ago, and I wired the main power wire to the battery, and the switch turns on it with a relay. Can't you do something similar with a relay? I am going to put the ARB CMA 12 air compressor on the same way, using a relay as a turn-on switch?
Old Dec 30, 2022 | 09:00 PM
traveldawg's Avatar
traveldawg
Thanks
This is how I did mine. That's 4 gauge wire on the DS battery terminal to a 60 amp circuit break through a solenoid controlled by an up fitter switch. On the camper side with that Victron I don't think you can use very large gauge wire as their terminals look like maybe 8 or 10 gauge at best. I installed a Renogy 40 amp DCDC charger. That 8 gauge wire goes to a fuse block inside the cab under the dash on the drivers side. For my air bag compressor and aux tank transfer fuel pump I used upfitter switchs.
Old Jan 1, 2023 | 01:57 PM
CT-Mike's Avatar
CT-Mike
Thanks for the ideas. The Victron DC-DC will accept 6 AWG wiring. My plan is to run number 4 from the batteries to an Anderson connector in the bed. Then number 4 on the camper side, and step it down to number 6 right at the Victron. Want to minimize losses/get max charging amps due to the length of the round trip circuit.
Michel153
Apr 2, 2014 09:16 PM
kneisl99
Oct 18, 2011 09:20 AM
turboale
Jun 19, 2006 09:10 AM
Ultraute
Electrical Systems/Wiring
Nov 12, 2004 12:31 AM
