Engine swap.
Old Dec 24, 2022 | 11:13 AM
Ol' 67's Avatar
Ol' 67
Engine swap.
Hey guys I'm new here and I have a few questions about the engine swap I wanna do. So I have a 1967 ford f250 2wd. It's got the 352 in it as of right now but I want to put my dad's old 400 in it that he built when he was my age. He had it in a 1976 f150 4x4. So I already know I need to do the front sump oil pan and oil pickup. But is there any other issues I would have bolting it in. I think the transmission is a T18 in my truck right now but I have the original bell housing for the 400 so I think belive that will be an issue. What about engine mounts? Any help would be great!!!
Old Dec 24, 2022 | 11:21 AM
f5fordgirl's Avatar
f5fordgirl
You will need the 400 flywheel, might need the 76 mount stands, not sure on that, may need the 76 clutch linkage.
Old Dec 24, 2022 | 11:26 AM
Ol' 67's Avatar
Ol' 67
I do still have all of those parts!
Old Dec 24, 2022 | 03:57 PM
lilorbie's Avatar
lilorbie
Years ago there was a company that made the engine mounts for this swap. I think their name was L & L. I don't know if they are still around or not.
Old Dec 24, 2022 | 04:24 PM
Ol' 67's Avatar
Ol' 67
Ok I looked on the website and I couldn't find the kit for this year but I'll keep looking. Thank you guys.
Old Dec 24, 2022 | 05:43 PM
RichS2659's Avatar
RichS2659
All you need are 2WD 1969-79 302 or 77-79 2WD 351M/400 engine perches as they are the same. The 4WD engine supports WILL NOT WORK. You can use the 351M/400 engine mounts. You will have to drill new holes in the crossmember. The clutch linkage should be similar. The T-18 and NP 435 use the same bell housing pattern.
Old Dec 24, 2022 | 06:22 PM
Ol' 67's Avatar
Ol' 67
I really appreciate all this information thank you guys, so the engine I already have like I said is the one my dad built, the other thing I just thought of was the oil dipstick, the rear sump that's on it the dip stick good right into the pan I already have a new front sump pan to put on it but I belive the front sump pans the dipstick goes threw the front of the engine somewhere by the timing cover any suggestions on converting that?
TheATeam
Dec 6, 2014 01:36 AM
Brandon_H
Oregon Chapter
33
Oct 20, 2013 12:26 PM
400Nut
Dec 23, 2006 01:17 PM
mbburchell2004
Feb 13, 2004 03:33 PM
