Anyone flat tow behind their RV? Looking for some advise on what vehicle to buy. I kinda like Jeeps or older (pre 2015) AWD Honda CR-V 's. Any recommendations appreciated. Prefer smaller then F150 or full size SUV. 4WD or AWD necessary. Manual transmission is OK.
I've flat towed one Explorer and a couple of Jeep TJ Wranglers. The Jeep is, IMO, the easiest to set up and tow. The wife liked the Jeep as a DD better than the Explorer.
I don't have personal experience with it, but I think if you're on this forum the obvious answer is a new Bronco. It may not be in the budget range you were considering though, since it is probably a bit more than an older CRV or Jeep.
While you CAN flat tow a Super Duty, and there is at least one forum member that does it behind his motorhome, that's not the direction I would go. If I had a motorhome, I would be looking at the lightest, easiest to tow vehicle, whatever that is.
